Question on cams. If someone had HD SE cams put into the bike when it was new, which cams were they most likely. I found SE1, SE2. How would these cams compare to comparable EV cams from Andrews? Would or should the dealer, that did this work, have changed the cam bearing, as well, or did they likely not bother. this would have been in a Softail, not bagger or Dyna. Thanks ahead of time for any input.
While I can't answer your cam question it depends on the year of the motor on whether or not the dealer would have even thought about changing the cam bearing.
What year are you asking about?
If I buy this one compression test will be first thing I do. I think the se1 cam is considered a HP cam, not tq/low end?
That would be correct and for it to properly perform you're static compression should be up around 10.5:1. If it was your ccp should be up around 190 psi maybe a little more with worked OEM heads and higher comp Pistons.. if the left they left the Pistons alone and just bolted on SE heads then your static comp would be up around 9.5-9.6:1 and ccp of around 170 psi.. knowing the cam and a compression test will tell a lot..
SE-1 cam (25487-87) was made by Crane and had a keyed gear. The SE-1 has since evolved (same specs) to a (part#)-A and (part#)-B but I have no idea of their respective manufacturer. And yes, they are awesome above 3500 rpm but nothing special below that. I've had 3, and they each failed on the bearing end within 15,000 miles. The B-138 bearing didn't fail, the hard surface flaked off the cam.
Being a 1996, it came with the inferior INA bearing which is fine with a stock cam, but won't hold up to a high lift/fast ramp "performance" cam. I honestly don't remember when HD started offering the "expanded" line of SE cams, late '90's maybe (?). If I had to guess, based on the assumption a dealer installed a performance cam circa 1994 I'd say it's likely SE-1. But as mentioned, there's no way to know which cam/bearing was used without taking it apart.
