Harley FXR shifter shaft length
Old Feb 12, 2020 | 04:53 AM
Wannes Smedts's Avatar
Wannes Smedts
Default Harley FXR shifter shaft length
Good day,
Anyone knows the length of an OEM FXR shift shaft (mid controls)
In the process of building custom mid controls for an open belt, I need to make sure the shaft passes the thick Primo motor plate + the 2" belt.
Any input on (aftermarket) suitable shafts (maybe a 2-piece with seperate shaft) is highly appreciated as well.
Thanks !
Old Feb 12, 2020 | 08:11 AM
Racepres's Avatar
Racepres
While true Forward Controls would Not reach thru the Primary... I can measure later today... let it warm up a bit!!!!
Old Feb 12, 2020 | 08:30 AM
Wannes Smedts
That would be great. Thanks in advance !
Old Feb 12, 2020 | 08:49 AM
Racepres's Avatar
Racepres
None of my business... but, Why not just reach straight back from Shifter to trans linkage??? Save a couple of Joints and Linkages!!!!
Which almost always equals "Slop"
Old Feb 12, 2020 | 09:25 AM
Wannes Smedts
The idea is to create a 'racy' back step (so no forward controls), using the OEM position of the shifter shaft as a link point.
Old Feb 12, 2020 | 10:40 AM
Racepres's Avatar
Racepres
6 inches total
Old Feb 12, 2020 | 11:19 AM
Wannes Smedts
Wow,
that's a lot more than I anticipated for.
This will even clear the open belt clutch.
Thanks a million for your efort !
Old Feb 12, 2020 | 12:00 PM
Racepres's Avatar
Racepres
Originally Posted by Wannes Smedts
Wow,
Just happens to be one on the shelf in the Shop.
Remember the splines are included in that, so a lever will steal 1/2 to 3/4 of an inch!!!
Old Feb 12, 2020 | 12:08 PM
Wannes Smedts
Yeah, I thought about that - should be no problem.
Now I just need to source one in Europe.
Old Feb 12, 2020 | 12:16 PM
Racepres's Avatar
Racepres
Good luck there... Part Number is 34621-84
BTW the Dyna may just be pretty close to the same
PN 34621-90
Damn... The dimension I gave you is most probably a 34621-82, as I think it may be from my '83... The Plot Thickens!!!!
Ask this guy for a measurement!!!!
https://www.ebay.com/p/1330042846
