Starter System Issue
Old Mar 8, 2020 | 05:03 PM
ezridermn's Avatar
ezridermn
Default Starter System Issue
I have an 84 FXRT (early model). It has run perfectly fine in the past. In fact, I rode the bike from April to August last year with no problems what so ever. In August I parked the bike and it sat unstarted for three months while I turned my attention to another ride. When I tried to start the FXRT after three months it acted a bit possessed. When I hit the starter button, the starter turned over and wouldn't stop running even when I released the starter button. It just kept grinding away. Then the ground wire at the battery became super hot and the only way to break the circuit was to undo the ground. Note: even when it was turning over it never turned over at the rate it would take to start the bike. The way it turned over sounded like the battery was on its way out. So I charged the battery and had it tested with a professional meter. It too looked to be in good shape. So not a battery issue either.
Then I thought huh, I got a starter system issue somewhere. In fact, I thought it was a bad solenoid that wouldn't disengage. Anyhow, I pulled the starter and the solenoid and tested them both and they appeared to be fine. But since I had everything apart I decided to put in both a new starter and a new solenoid. Yah, you know the end of this story...got them installed, hit the starter button and the same thing happened. (ugh) Then on second thought, maybe it was, in fact, the battery so I jumped the bike from another battery...same thing.
Now I don't know what to think. If you have any suggestions I would appreciate hearing them. Thanks!
Old Mar 8, 2020 | 05:16 PM
EVOrider's Avatar
EVOrider
I wish I could help on your problem.....
But, Could you post a picture of the FXRT. I had a 1984 FXRT years ago and it was my most favorite bike I ever had. I still regret letting it go....
Thanks
Old Mar 8, 2020 | 05:49 PM
86glider's Avatar
86glider
Sounds like a stuck starter relay
Old Mar 8, 2020 | 07:29 PM
ezridermn's Avatar
ezridermn
Default Private Message
Thanks
Hi EVOrider. I sent you a private message. Did you get it?
Old Mar 8, 2020 | 07:30 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Old Mar 15, 2020 | 05:31 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
What does tested with a professional meter mean?
How old is this battery?
If the starter is cranking slow, it is usually a sign of insufficient current to the starter, either due a weak battery or a poor electrical connection.
Either of these problems can cause a starter to "run on", due to the configuration of the solenoid on these old systems.
Old Mar 16, 2020 | 08:36 PM
Beemervet's Avatar
Beemervet
Thanks
We like pics.........
Old Mar 17, 2020 | 10:31 AM
tomfiii's Avatar
tomfiii
Could be the button switch itself, have friends who's bike started to start while riding found problem in button switch due to corrosion.
Old Mar 17, 2020 | 01:55 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Crickets....
Old Mar 20, 2020 | 09:13 PM
mike131's Avatar
mike131
yeah sounds like a stuck relay or bad battery or lack of current "bad connection"
