Starter System Issue
Old Mar 21, 2020 | 05:53 PM
1997bagger's Avatar
1997bagger
If the starter is cranking slow, it is usually a sign of insufficient current to the starter, either due a weak battery or a poor electrical connection.
Either of these problems can cause a starter to "run on", due to the configuration of the solenoid on these old systems.
Don't know if the OP fixed the problem but Dan is correct, a starter can stay engaged due to low supply voltage, most likely a bad ground by reading the issue plus getting hot. A bad relay won't have any effect on the slow cranking issue mentioned, it only knows engage or disengage.
Wampa Stomper
Shovelhead
Sep 26, 2015 06:58 PM
pjb
EVO
May 8, 2012 07:15 AM
Mar 26, 2012 06:54 PM
radio915
20
Apr 15, 2011 08:58 PM
hometoo
General Topics/Tech Tips
Mar 25, 2009 10:54 PM
