For starters I would pick up the idle to at least 950 rpm.. It's idling way to low. And as Nomadmax mentioned, pop your pushrod tubes to see if you have a loose adjustable pushrod. If you have the OEM pushrods, then I would suspect a bad lifter or lifters. DO you have a FSM and are you mechanically inclined? If not you better take it to a repair shop...
I dont know whats a FSM....I cant count on any repair shop here in Saudi (not even the dealership)... i have to do it myself.
so pushrods inspection and then lifters...
I'll order both and change them any ways... do i have to take the engine off of the frame to do that or not?
FSM=Factory Service Manual.. It'l walk you through the process of diagnosing a noisy valve train.. I suggest you do not touch the bike till you get one... They are still Available through the dealer.. And no you don't have to remove the motor.. Once you get your FSM come back and we'll help you through it...
If you get to the point of removing rocker covers, remember to follow the service manual instructions absolutely to the letter, to avoid engine damage, especially on reassembly.
98hotrodfatboy can get you through this, he knows his stuff.
Get a clean work area, and some ziplock bags,
Don`t mix up lifters and pushrods, keep them organized so that they go back in the same location.
