Shifter Lever removal help
Old Mar 29, 2020 | 04:55 AM
staged67gspwr's Avatar
staged67gspwr
Default Shifter Lever removal help
Anyone can help out on how to remove shifter lever on a 99 fatboy?its the splined peice im refering to any help appreciated!!
Old Mar 29, 2020 | 05:41 AM
0maha's Avatar
0maha
Loosen the pinch bolt and slide it off.
They can get crudded up over time. Might take some persuasion if it hasn't been removed for a while.
Old Mar 29, 2020 | 05:49 AM
bagga's Avatar
bagga
take the bolt out after you get it loose. then tap it with a hammer or pry on it with a screw driver. bolt must be removed.
Old Mar 29, 2020 | 06:02 AM
0maha's Avatar
0maha
Yes. Not just loosen. You have to pull the bolt out.
Old Mar 29, 2020 | 06:11 AM
staged67gspwr
There is no bolt,only attachement is with the shifter arm,and it just slides out but the problem is i cant slide it back enough it hits the inner primary
Old Mar 29, 2020 | 06:15 AM
staged67gspwr
H
Here some pics
Old Mar 29, 2020 | 06:45 AM
bagga's Avatar
bagga
that's a different story. I don't know about that one. maybe take that bracket off?
Old Mar 29, 2020 | 06:48 AM
RANGER73's Avatar
RANGER73
Jack it up and remove the jiffy stand bracket.
Old Mar 29, 2020 | 07:05 AM
staged67gspwr
Yea i was thinking the same the bracket has to come off or loosened,thanks guys!!
Old Mar 29, 2020 | 05:58 PM
mike131's Avatar
mike131
DaveNBPT
2014-2024 Touring Models
17
Apr 18, 2016 09:51 PM
Ta2dean
Mar 12, 2012 05:37 PM
AmmoLT
Jul 18, 2011 12:50 PM
Evo94
Jan 3, 2009 03:42 AM
Swampman
Jul 29, 2008 01:43 PM
