Turn Signal Issues
Old Apr 16, 2020 | 08:44 PM
Gunslingertom's Avatar
Gunslingertom
Originally Posted by C3DW
I can't find a module. I checked the areas suggested and no luck. The headlight does not come on in the IGN position. I presume the self-cancel is on a timer. The turn signal does not automatically shut off. I did try turning to the "lights" setting on the ignition while the signal was blinking and it stopped blinking when switched to lights. I was also wondering about a weak battery as also suggested so I used a fresh battery to run the lights and signals. There must be a module somewhere or flasher. I have not taken the dash pod off to root around in there but I think that will be my net step. Thanks for helping.
If you need a module, I have 2 that work. I would send you one for the cost of shipping. I've always replaced mine with Badlands modules for LED's.
Old Apr 17, 2020 | 11:01 AM
C3DW's Avatar
C3DW
Stage IV
I found the turn signal module which was staring me in the face. Kind of a pain to get it out but got that done. I checked the voltage at the orange wire and it is 12 in the IGN phase and drops to 11 in the "Light" phase. What do you think is causing that drop? Is there a way to test the module itself?
Old Apr 17, 2020 | 11:22 AM
C3DW's Avatar
C3DW
Stage IV
Default Turn signals
Follow up: After finding and disconnecting the turn signal module (which I got to through the dash which was a pain) and checking the voltage I went through the system and cleaned all the terminals I could get to and put it back together and VOILA the system is fully functional. Thank you for all the help and the quick replies. Getting to use your experience is a big help for us novices!
Old Apr 17, 2020 | 11:44 AM
t150vej's Avatar
t150vej
Glad you got sorted out
I had a feeling it was low voltage from the symptoms described. My reasons for asking about the other things was to rule out a possibility of the wiring being altered at the switch/breakers.
Following up a post with results, will always make forum members more likely to help. Good job...
hydrantwrench
Electrical/Lighting/Alarm
20
Apr 1, 2020 09:15 PM
IndyIN
2014-2024 Touring Models
Jul 10, 2016 08:15 AM
Odelay
Sep 5, 2014 11:16 AM
sberman431
Nov 9, 2012 08:03 AM
ultravista
23
Jan 16, 2006 09:50 PM
