Lubricant question
Old Apr 29, 2020 | 10:55 PM
AbnRanger4's Avatar
AbnRanger4
Default Lubricant question
I’m using Harley 20w50 conventional oil in engine and Formula Plus in primary and tranny. Is there a better option that I should know about. I’ve read all the info on the Valvoline VR1. Some run 20w50 conventional in the primary but I’ve read a lot about why not to do that also. I know it’s a loaded question. If using the current fluids is best, I’m fine with that. I know a local shop that sells and recommends Drag Specialties 20W50 for engine, Drag primary oil for primary and drag gear oil for tranny. It is a little less expensive than Harley stuff but not much. Thanks again for the info.
Old Apr 30, 2020 | 07:26 AM
TedMan's Avatar
TedMan
You know oil threads and opinions are like a**holes, eveyone has one. FWIW, you are fine, but I would consider putting Redline or Mobil 1 in the tranny.
Old Apr 30, 2020 | 07:52 AM
daven9113's Avatar
daven9113
You will read opinions about oil forever! I recommend you support the local shop and get the Drag Specialties oils because it is cheaper and better than Harley stuff. One opinion that is fairly consistent is to change your oil at regular intervals.
Rangers lead the way!
Old Apr 30, 2020 | 08:53 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
What you are using is fine.
Cmonks91
May 8, 2013 08:32 PM
Figstr
Jan 24, 2012 12:01 PM
Tropical Andy
Jun 6, 2010 08:29 PM
eagle56
Dec 31, 2009 08:21 AM
moondog99
Sep 22, 2007 07:53 PM
