Difference between primary and engine for lube
Old May 7, 2013 | 10:00 PM
Cmonks91's Avatar
Cmonks91
Default Difference between primary and engine for lube
Ive read a lot on what oil to use for which, a lot of guys are using the same for all 3 holes, some guys buy 3 different.. My question is what is the difference in your engine oil and primary oil. What kind of oils should they be?
Im running redline shockproof in my trans and most likely mobil 1 v-twin 20 50 but im not certain on what i should put in the primary. What is the "primary" exactly? Just my cluch ?
Thanks guys
Old May 7, 2013 | 10:19 PM
Midgard's Avatar
Midgard
where we could go with this lol
Old May 7, 2013 | 10:39 PM
Cmonks91's Avatar
Cmonks91
Thanks for your detailed reply
Old May 7, 2013 | 10:40 PM
Midgard's Avatar
Midgard
You are very welcome!
ps; try the search feature
Old May 8, 2013 | 04:08 AM
goats's Avatar
goats
lol
oils are widely debated with many different opinions and preferences.
the primary is where you do your clutch adjustment, the big round removable derby cover is the part you remove for this adjustment and also where you pour the oil in after you have drained it. look on the left hand side of the bike.
Old May 8, 2013 | 08:46 AM
hdgzr's Avatar
hdgzr
The owner's manual also answers your question. Anything that meets the recommended specs should be fine. Some use ATF, some use diesel-rated engine oil...and some even use what The Factory recommends; the same for all three holes.
Old May 8, 2013 | 09:11 AM
Misbehaven's Avatar
Misbehaven
I have always used the same lube in the engine and primary. A for the gearbox I have always used a heavier gear lube like Redline or Amsoil.
Old May 8, 2013 | 10:08 AM
t03cutt3r's Avatar
t03cutt3r
My flavor choices. The Tranny juice really smoothed out the shifting as many will attest to.
Mobil 1
V-Twin 20W-50 in thecrank
Amsoil
75w-140 Severe Gear in the trans
10W-40 MCF in the primary
Old May 8, 2013 | 12:20 PM
2006FLST's Avatar
2006FLST
When I used fluid in my primary it was mobil 1.
Old May 8, 2013 | 02:22 PM
TheTroupe's Avatar
TheTroupe
All Mobil 1
V-Twin 20W-50 in the crank
75w-90 Gear Oil in the trans
(I live in New England, you may want a thicker oil where you live)
Racing 4T 10W-40 MCF in the primary
There is a reason for three holes and an oil for each hole. That is not to say you can't put the same oil in each, many people do, I just don't agree with them.
