Difference between primary and engine for lube
Old May 8, 2013 | 03:11 PM
NoRegerts's Avatar
NoRegerts
I use AmsOil in all three. Severe gear for the trans, primary for the primary, and 20-50w for the crank.
I think the reason for the different holes is the lifespan of the oil in each. The trans is thick and won't break down as fast as the oil in the crank which is constantly exposed to high engine temps and combustion.
Old May 8, 2013 | 03:50 PM
Snowyone's Avatar
Snowyone
Default three holes
I'm running a 2011 Fatboy Lo and use Amsoil 20-50 in the engine, 80-90 in the tranny and 10-40 in the primary. I've used type F tranny fluid in the primary for years with great results but Amsoil recommended the 10-40 so that's where I'm at. The ATF has so many detergents in it, primary chains and the clutch discs seemed to last forever. I'm going to be breaking in a new engine real soon I hope(if the rest of the parts arrive)and will be going back to dino oil in the engine.
Old May 8, 2013 | 05:47 PM
Cmonks91's Avatar
Cmonks91
Are you guys using a non synthetic in the primary?
Old May 8, 2013 | 07:15 PM
Bone Doc's Avatar
Bone Doc
If you browse to this subforum:
Harley Davidson Forums> General Harley Davidson Tech Forums> Oil and Oil Related Topics
the top three Sticky's show you what people are using in each hole. Here is the latest:
Crankcase oil
https://www.hdforums.com/forum/oil-a...45-a-poll.html
Transmission fluid
https://www.hdforums.com/forum/oil-a...46-a-poll.html
Primary fluid
https://www.hdforums.com/forum/oil-a...47-a-poll.html
To give you my personal choice, I use synthetic in all 3 holes
Mobil 1 V-Twin 20w50 in the crank and primary and Mobil 1 75w90 gear lube in the tranny.
Old May 8, 2013 | 07:24 PM
BigMESA's Avatar
BigMESA
I use Mobil 1 V-Twin 20w50 in all 3 holes.
Old May 8, 2013 | 07:57 PM
elizer's Avatar
elizer
things can vary bike to bike. I used 20-50 mobile in all 3... changed out my clutch cables and switched to gear lube 75-90 mobile and id ont like the feel of the shifts... its supposed to be almost the same weight as the 20-50 but im gonna either go back to 20-50 or go something heavier.
Old May 8, 2013 | 08:32 PM
goats's Avatar
goats
i like amsoil 20 50 in the engine and primary.
i was using spectro in the tranny but discovered i was out AFTER i drained it so i threw amsoil 20 50 in there too just so i could meet the group for a ride.
could be mistaken but i think i was using the spectro that baker recommends for that tranny.
jphillips
Sep 3, 2014 10:03 AM
kreeess
Oil Archive (no new posts)
Aug 19, 2014 05:55 PM
HighestHD883
Jul 30, 2014 03:35 AM
harleyglen
Sep 29, 2013 09:21 PM
tomtek
Oct 19, 2010 06:36 PM
