Speedometer failed
Old May 16, 2020 | 12:32 PM
rol427's Avatar
rol427
Default Speedometer failed
Greetings,
I have a '91 FXSTC which has the speedometer driven off of the front wheel. The speedometer needle has been shaking and today it shook worse and then dropped to zero. This also disabled the odometer which is how I time my fuel stops because there is no gas guage. I removed the speedometer and it does not appear to be serviceable. I also pushed the bike and I can see the input cable turning. Is my only option to replace the speedometer? Thank you for your input.
Old May 16, 2020 | 04:31 PM
yellowstone kelly's Avatar
yellowstone kelly
I don't know where you're located, but if you do a Google search for "Motorcycle speedometer repair" it will find many places that repair speedometers.
I've never used any of these, so I can't recommend one over any others. And I have no idea what they charge to repair a speedo.
It may turn out that buying a replacement will be the best option...
Good luck.
Old May 16, 2020 | 05:13 PM
WP50's Avatar
WP50
Ya need to ck the cable. Have seen the cable turn as you have ck'd.
It can be turned with just enough friction between the ends of a broken cable while turning the front wheel
Pull the cable out and make sure it's OK.
WP
Old May 16, 2020 | 05:31 PM
FreedomRider's Avatar
FreedomRider
I've also had the drive on the front wheel go bad ... don't waist time with the aftermerket junk, buy the OEM unit
Old May 16, 2020 | 06:36 PM
Dr.Hess's Avatar
Dr.Hess
Most likely the cable went out, taking out the drive unit with it. As FredomRider says, only buy the OEM drive unit.
Old May 16, 2020 | 07:18 PM
Yankee Dog's Avatar
Yankee Dog
The speedo can be taken apart. It is time consuming and tedious prying the stainless trim ring off but it can be done. You need to go slow and be methodical. There are threads here on how to do it. Also do a google search and you will find some info also.
However, I agree with the others, totally remove your cable and inspect. Also remove the drive gear and try to find any problems with that. Do both of those first. If your drive gear and cable seem OK, then the easiest is to try and find a speedo used. You don't have much of a choice. I thought I saw a new repro a few years back. It was pretty close to original but did not have the harley name on it. Good luck.
Oh yeah, almost forgot, graphite powder is your friend when it's time to lube your inner cable. YD
Old May 16, 2020 | 08:49 PM
rizzo's Avatar
rizzo
If it is the drive, make sure you get the correct drive ratio. If you get OEM it should be correct, aftermarket double check.
Old May 17, 2020 | 07:47 AM
grbrown's Avatar
grbrown
You speedo not working is a symptom - we need to find out what caused it before taking any action! Physically detach the speedo cable at both ends and carefully remove the inner. The most common fault is that the inner seizes inside the outer, through lack of lubrication plus ingress of water, then breaks. If your inner has broken, buy a complete new cable, inner and outer. Check the drive unit on the front axle for free movement, when turning the wheel over, as that can also suffer from water ingress. Only then can we check the speedo itself. I'm sure there are a few firms who can service and repair them, IIRC.
Old May 17, 2020 | 08:19 AM
rivercityslim's Avatar
rivercityslim
I've had this happen twice over the years -- once was the cable; the second time the drive unit.
Old May 17, 2020 | 10:58 AM
Dr.Hess's Avatar
Dr.Hess
I'm at around 8 or 9 cables and/or drive units. Mine's mounted on the left, and I think that made things worse. The current set is all HD and it is lasting better.
