Speedometer failed
Old May 18, 2020 | 01:51 PM
rol427's Avatar
rol427
I pulled the cable out and it is in one piece. Even at the slow pace I can push at the cable rotates smoothly. I'm going to get a new unit from my dealer rather than try to fix it.
Thank you all for the comments.
Old May 19, 2020 | 05:28 PM
1skrewsloose's Avatar
1skrewsloose
I wonder what goes on with these things, mine started going from 50 to 80 back and forth, gave it some good slaps and has worked fine since. At around 30 k miles. now at 50.
Old May 23, 2020 | 10:32 AM
rivercityslim's Avatar
rivercityslim
Originally Posted by Dr.Hess
I'm at around 8 or 9 cables and/or drive units. Mine's mounted on the left, and I think that made things worse. The current set is all HD and it is lasting better.
Mine's an '89, also mounted on the left. When the drive unit went last fall I replaced the cable as well just to be on the safe side.
Old May 23, 2020 | 11:29 AM
evotrike's Avatar
evotrike
Pull cable off drive unit, leave hooked to speedo. Hook up drill motor to loose end. Will tell you if cable or speedo is bad. Can't remember if it's forward or reverse, though.
Old May 23, 2020 | 02:06 PM
Uncle G.'s Avatar
Uncle G.
Good luck finding an OEM drive unit. They’ve been out of production for many years and are more scarce than rocking horse poop.
I had one but let I go with my wrecked Evo when I sold the remains.
Old May 23, 2020 | 05:15 PM
Beemervet's Avatar
Beemervet
Not a good idea. This can be diagnosed quickly without risking the cable or speedo. Yah, I know, someone's cousin's boyfriend did it and it was cool. Too many rpms.
Old May 23, 2020 | 09:41 PM
evotrike's Avatar
evotrike
Actually, I did it to diagnose my drive. Ran it slow, no problem. Told me what I needed to know.
. A bit negative today?
Old May 23, 2020 | 11:07 PM
Beemervet's Avatar
Beemervet
Don't ask...
sampansam
Nov 12, 2019 11:52 AM
cskarns
EVO
27
Apr 3, 2018 06:29 PM
Dumaine
Apr 4, 2009 12:27 PM
suprsnake
Jun 24, 2007 12:00 PM
HDF Tech
Sep 23, 2005 12:18 PM
