1996 Road King Evo (carb) - Purchase Help!?
Old May 28, 2020 | 09:03 PM
Dan Osborne's Avatar
Dan Osborne
Stage IV
Default 1996 Road King Evo (carb) - Purchase Decision Help!?
Hi guys, just joined the forum, wondering if anybody can help me out. I have an opportunity to trade an old truck I am selling for a 1996 Road King Evo with 43,000 miles - the trade value of my truck is about $6,000.
I’ve had lots of bikes over the past 25 years, but never a Harley. Looking for advice on what I should be looking out for, any common issues with this model of bike, and any other relevant or helpful info you may be able to arm me with on this particular model before I make a decision!
Thank you all in advance for any advice & assistance you may have! Really appreciate it!
Dan
This is the bike I’m considering trading for.
Old May 28, 2020 | 09:51 PM
ZachE's Avatar
ZachE
96 is a good bike, that one looks well taken care of.
I've got a 94. 40-44 mpg, if it doesn't have a big jet kit and thunder slide in it.
Neat age range, as you can take some parts going back to 89 and all the way up to 2006 for quite a lot of the other hardware.
94-96 share the same frame, which means that some parts: the saddle, rear saddle bag guards, and license plate mount are all 2 year parts... The battery on them are smaller than the later model bikes, so keep a fresh one in her. Harley shop doesn't normally stock one that size, but Autozone and Batterys Plus do. The frame is narrower, and battery box is not as deep as the rest of the harley batteries.
96 has upgraded switch gear on the handlebars is the late model, first year for those.
Stock cam has no valve overlap, so they are a bit anemic. Andrews EV13 or EV27 are two that work well, and may well already have one in it. The inner cam bearing gets a bad rap, but at the same time if it hasn't gone yet, it probably won't. The stock lifters have a bulletin out for 25k to be checked on. But, if she sounds like an angry sewing machine, without any tapping they ought to be happy.
The clutch should still be the old style, which takes a puller tool to take apart. The 1998 up style is a decent upgrade if you ever get in there, and the hubs are cheap on ebay... They've got a row of 10mm bolts, and makes changing springs easy if you want to lessen the lever tension. The stock clutch for my wrist, was a bit much after a couple years of riding her.
ECB brake pads on the front end improve the braking a good bit, single pot calipers are acceptable.
Air forks on the front, are cool because you can swap the fork oil with a vacuum pump and fill the forks like they are a lower unit on an outboard.
Heavy weight fork oil, helps the brake dive a lot. The rear shocks you can upgrade, also air, off late model stuff. 2009 equipment makes for a nicer ride. Get a shock pump, rather than hooking up to an air compressor.
Have fun, you'll like her.
Old May 28, 2020 | 09:58 PM
0maha's Avatar
0maha
Nothing wrong with a 96 Evo, but it's not worth $6k. So other than getting the short end of the deal, go for it.
Old May 28, 2020 | 11:01 PM
daven9113's Avatar
daven9113
That looks like it's pretty bone stock. If you can sell your truck for $6K, then you would have more choices of Evos on the market, and might even get one with upgrades and less miles. If you like the bike, and feel comfortable with the deal, then do it. If you were to buy it outright, top dollar offer would be $5K if it's clean. Road Kings are great looking bikes. Good luck.
Old May 29, 2020 | 06:51 AM
Dan Osborne
Stage IV
Thanks guys for the thoughts/advice!
Old May 29, 2020 | 10:30 AM
im's Avatar
im
Looking at just photo shown that was taken from a distance in low lighting the motorcycle shows nice curb appeal.
Consider review of tire age.
Keep in mind that sometimes people end up with 10-15 year old tires on their motorcycles and the rubber becomes rock hard.
New tires should be under $500 for a carry in mount/balance.
Consider review of battery age.
The front sliders look like they require some clear coat removal and then polishing and you can do that yourself if you have a motorcycle jack.
The bike should prove reliable if previous owner took care of it and if you learn how to work on it.
Really simple machine.
If you are someone that needs to take a bike to dealer for everything then bike might not be for you since bike might be as old as some techs..
By using a factory service manual and this forum the bike should remain functional for some time if you are willing to work on it yourself with simple tools.
In regards to price.
People have all kinds of measures but i find that just about any big twin touring motorcycle that has nice curb appeal, rides straight and has a clean title will have a minimum value of $5,000 USA dollars.
Old May 29, 2020 | 05:18 PM
86glider's Avatar
86glider
Sweet looking bike.Maybe he can help w/the price for tires? At least you'll feel you got something to go w/it.Good luck.
Old May 29, 2020 | 06:07 PM
Dan Osborne
Stage IV
I should have mentioned in my original post, the bike also has new tires and a new set of Vance and Hines Head Pipes and Mufflers. I think that should help bring up the value in this trade, right?!
Old May 29, 2020 | 07:46 PM
0maha's Avatar
0maha
Seems to me you could sell your truck for what? $7k? $8k?
Whatever the number, you sell it and go bike shopping.
Or you take this deal, knowing you'll be leaving money on the table. But in exchange, you avoid the headaches of selling your truck.
It's not like this trade you're looking at is ridiculously upside down. Couple of grand maybe.
The bike looks good. Personally, if I was in the market I'd call it $4500 ish cash.
Old May 30, 2020 | 08:46 AM
86glider's Avatar
86glider
If you like it and don’t have any attachments to the truck ,do it.Mileage is low and looks like it was cared for.The guys here can help if anything arises.
