Trouble getting neutral.
Old Jun 8, 2020 | 06:46 AM
flhchaz's Avatar
flhchaz
Originally Posted by FreedomRider
sounds like the spring plate is coming apart in the middle of the clutch pack ... that's where I would look
this would be the first thing I would check. My 97 started to get hard to shift, then would barely shift. Sure enough the spring plate lost it rivets. I replaced it with the HD police clutch pack (no spring plate) works fine now
Old Jun 8, 2020 | 05:37 PM
mike131's Avatar
mike131
I agree the 5 speed is a great shifting transmission, especially with the latest design shift drum and shifter pawl.
But difficulty finding neutral has been the nature of the beast on many 5 speed transmissions, especially the earlier models before the roller detent shift drum.
Hey Man:
If this is a new issue, you may consider looking at your clutch plates and (as 1997 bagger suggested), make sure that riveted spring plate hasn`t failed, it can make a mess.
Exactly right!!!
Old Jun 9, 2020 | 05:34 PM
Hey Man's Avatar
Hey Man
I tried adjusting my clutch again. This time I ran the clutch rod until stop then in 1/4 turn more to let oil drain off. After about a 1/2 hour I screwed it out then back in until I felt it stop. Then I turned it back out 1/4 turn and lock it down. Adjusted my cable and badda-bing I'm getting Neutral a lot easier. I'll run it like that for awhile and if I feel it necessary I'll adjust it again and back out the rod to about 1/3 of a turn.
BMCsteve
Jul 25, 2017 10:12 PM
Mity2
Aug 21, 2016 09:02 AM
glebo
Aug 7, 2007 08:58 AM
twowheelsforever
Jul 8, 2006 03:44 PM
lowglide88
Apr 5, 2006 08:30 PM
