Finding neutral easy and hard
Old Jun 17, 2020 | 03:42 PM
TedMan's Avatar
TedMan
Default Finding neutral easy and hard
When my 96 flstn is parked engine off, I have no prob finding N. But if I am sitting at a light with bike running, it's near impossible. Normal, or clutch adjustment in order?
Old Jun 17, 2020 | 03:47 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Pretty normal for my bikes.
You can also find N easily if you are moving slow as in pulling up to the red light.
Old Jun 17, 2020 | 03:50 PM
daven9113's Avatar
daven9113
Should not be normal. Adjustment is in order for the clutch. And check primary chain adjustment while you are at it.
Old Jun 17, 2020 | 04:11 PM
Bass Player's Avatar
Bass Player
Adjustment and rolling finding neutral will work as said. Another thing, how much oil in the primary? If it's to the bottom of the derby cover there is too much.
Old Jun 17, 2020 | 04:21 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Normal for the past 31 years on my Softail, two different gearsets and shift drums....
Old Jun 17, 2020 | 09:28 PM
TedMan's Avatar
TedMan
Thanks all. Fluid is at proper level bottom of the plates and chain was recently adjusted. I think I'll do a full adjustment and see. Thanks again for your perspective.
Old Jun 17, 2020 | 10:40 PM
EVOrider's Avatar
EVOrider
My 1998 Ultra was doing similar symptoms as your bike. Clutch was adjusted properly. Primary chain was properly. Oil level was good.
Ended up being a worn clutch basket. The plates were digging in and hanging up. The clutch was partial engaging.
Old Jun 18, 2020 | 04:52 AM
grbrown's Avatar
grbrown
I found a set of plus-1 Barnett Kevlar plates helped a little. Also on my bike I set the adjustment at the clutch as per the book, but reduce cable slack at the lever, to improve things just a little. We can't do so every time, but snicking into neutral while rolling to a stop works wonders.
Old Jun 18, 2020 | 09:13 AM
TedMan's Avatar
TedMan
Original owner used to run Mobil 1 syn in the primary. Always thought that was overkill for the Primary, and for convenience put in Formula +. Don't know if that would make a difference at all. Bike only has 20k miles, so hopefully clutch basket is not worn out already, but if it gets worse, I will take a look and maybe go Barnett. Thanks again for input.
Old Jun 18, 2020 | 09:16 AM
TedMan's Avatar
TedMan
Thanks, I loosened up a little at the lever, as well, because I like clutch engagement closer to the grip. Not more than an 1/8" though.
