EVO piston orientation
Old Jul 14, 2020 | 08:01 PM
franka's Avatar
franka
Default EVO piston orientation
Ok i have a 1997 softail. I had a crank pin go south so i sent it out to be rebuilt and sent the cylinders to be bored. I got the cylinders back with piston supplied by the shop that did the work. He marked the pistons with a arrow cam side but that put the arrow stamped on top pointing to the back. the pistons are made by jcc and have a height spot on a wristpin boss and said it is cam side. So is this right or should the arrow go to the front?
Old Jul 14, 2020 | 10:11 PM
drm1978's Avatar
drm1978
For stock pistons, the arrows face forward. For after market pistons, the arrows probably need to be oriented toward one another so that the larger cutout in the piston crown aligns with the larger intake valve.
-Dave
Old Jul 15, 2020 | 06:45 AM
franka's Avatar
franka
The cutouts are the same sizes,
Old Jul 15, 2020 | 08:17 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Never heard of jcc.. can you post a pick of the tops and skirts... Are they flat tops or domed
Old Jul 15, 2020 | 08:54 AM
grbrown's Avatar
grbrown
Red face
How about checking with your shop? Simpler surely than explaining everything to us!
Old Jul 15, 2020 | 09:19 AM
franka's Avatar
franka
Default evo piston orientation
Black arrow was put on by machine shop that sold me the pistons. that would put the stamped arrow to the back and the other piston was marked so the stamped arrow would face forward, But when i called him to make sure this was right was told the divot on the pin boss should be on the cam side on both pistons that would put the stamped piston facing to the back. After getting two different answers from him i just want to make sure.
Old Jul 15, 2020 | 09:27 AM
grbrown's Avatar
grbrown
Red face
Better understand now why you ask! As for the correct answer....
Old Jul 15, 2020 | 09:29 AM
franka's Avatar
franka
Because i have got two different answers from him and i need to be sure.
Old Jul 15, 2020 | 09:38 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I suggest you call the piston manufacturer and ask them, the guy you are asking does not seem to know...
Hopefully one of the expert engine builders on the forum will jump in.
Old Jul 15, 2020 | 09:43 AM
98hotrodfatboy
Well according to that picture of the bottom one, of the top of the piston... With the arrow pointing forward that's pointing to your exhaust valve which would be oriented on the front cylinder... Those valve reliefs definitely not the same size.. with the front being the smaller one indicating it is indeed the front cylinder....
