emergency fix
Old Jul 17, 2020 | 01:02 PM
lunyty1's Avatar
lunyty1
Default emergency fix
i/m on a road trip and my dual fire ignition died,,,,,my friend has an extra crane hi-4 single fire but all i have is my dual fire coil,,,,,,,,any way to make this work ???? i know it's a crazy question but crazy times call for crazy measures
Old Jul 17, 2020 | 01:07 PM
Racepres's Avatar
Racepres
Put the two Trigger wires [blk and wht] on the opposite side of the coil from the O.E. white wire [switched 12v] and Go... till ya get where you can change it... not thousands of miles preferably..
I thought the Hy-4 was either single or dual Fire...Selectable??
LMK if this don't work... but... triggers is triggers, IMO
Old Jul 17, 2020 | 01:12 PM
t150vej's Avatar
t150vej
Red is power in to module, terminated at the + of the coil.
Black from the module is trigger for the coil.
Brown to tach,
Green to VOES.
Tape off white wire
Mode Sel Dial on 4 (or 5)
All other dials set at 5
Hope this helps
Should work
Old Jul 17, 2020 | 08:32 PM
mike131's Avatar
mike131
should work fine, 3 ohm coil?
Old Jul 20, 2020 | 11:13 PM
Dehammer's Avatar
Dehammer
If I remember right...... that should have selectable switches for kickstart and single fire.
ETA..... replace ASAP, they have a known problem of cutting out in the heat.
Old Jul 21, 2020 | 07:49 AM
LQQK_OUT's Avatar
LQQK_OUT
If the OP was looking for an instruction sheet, here it is.
http://www.nightrider.com/biketech/d..._hi4_race2.pdf
BaggerBill103
19
May 19, 2020 08:39 AM
row jimmie
EVO
Apr 5, 2018 06:19 AM
tymatt67
Sep 23, 2012 08:54 AM
waynemags
EVO
May 28, 2009 02:41 PM
dts
Aug 17, 2007 06:15 PM
