Dumb Question
Old Aug 5, 2020 | 06:37 PM
Mountainkowboy's Avatar
Mountainkowboy
Default Dumb Question
Here goes.....does it matter if I just start her up vs "priming" the oil system first?
The way I understand the oil system is that the engine gets oil first. Once the engine is "done" with it, the scavenge pump then pushes it through the oil cooler and the filter, then returns to the tank. So as long as there is oil in the tank there isn't any need to prime anything.....right?
Old Aug 5, 2020 | 07:16 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
What I have done is remove the cover over the check ball on the oil pump, remove the spring and ball and the oil should run into the pump, when it starts to come out of the opening replace the ball, spring and cover.
Some guys squirt oil in there but I never needed to.
Old Aug 5, 2020 | 07:18 PM
Mountainkowboy
I never drained the pump or engine during this whole thing.
Old Aug 5, 2020 | 07:29 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
The just fire it up.
Old Aug 5, 2020 | 08:17 PM
Mountainkowboy
That's what I was thinkin....just checkin.
Old Aug 6, 2020 | 04:25 AM
carlgrover's Avatar
carlgrover
When I got mine back together after an engine rebuild including a new oil pump, I had to pour some oil down into the oil pump to get it flowing.
carl
Old Aug 6, 2020 | 05:47 AM
eighteight's Avatar
eighteight
Pull the plugs and crank engine till oil light goes out.
Install plugs and start
Beltdriven
EVO
18
Dec 16, 2014 08:32 PM
marekm1234
Nov 3, 2013 02:05 AM
towbyl
Oil Archive (no new posts)
Mar 7, 2009 11:51 AM
bronk
Apr 16, 2007 12:33 PM
BTROUT
Feb 1, 2006 12:12 AM
