Too lean?
Old Nov 22, 2020 | 03:29 PM
Yankee Dog's Avatar
Yankee Dog
Originally Posted by Fureek
Hey Yankee Dog, good to hear from you again brother. No popping on deceleration. Always use anti seize. Seems to run okay, feels a little rougher than before but got better throttle response. Might be feeling the power more. I thought of maybe taking the mixture out another 1/4 turn. Keeping an eye on the plugs for any tell-tale signs.
Running RN12YC plugs.
Just found a local bike shop with old school mechanic. He’s got a ‘97 Heritage getting 50 mpg here at altitude. I will be taking this in to him to get fine tuned. He’s been really cool about sharing knowledge.
you get a hankerin’ to head to Az, give me a holler.
I am doing well, thanks, but be careful, might just take you up on that offer as I look out the window watching snow.
Taking the mixture out to up to 3 is OK to do. Try 2 then 2-1/2 and see what happens.
The reason 98hotrodfatboy asked about timing and ping is the color change on the grounding strap of your spark plug should be right around at the bend of the ground strap. It's the same reason I mentioned one step cooler in the plug.
Sometimes timing needs to be backed off with certain mods and fine tuning (only really a few degrees). I would try a one step colder plug, really won't hurt anything. But you are really close...
https://www.dragstuff.com/techarticl...ead-plugs.html
Old Nov 22, 2020 | 06:23 PM
t150vej's Avatar
t150vej
You will never get an accurate timing or heat range reading with anti-seize on the plugs, especially with that much in post 1 photo.
The plug requires heat transfer from the plug threads to the cylinder head... anti -seize interferes with that process.
Old Nov 22, 2020 | 11:25 PM
Fureek's Avatar
Fureek
popping in new plugs in the morning. Will be more careful with the anti seize.
800screws
General Topics/Tech Tips
Feb 23, 2015 09:24 PM
CSS_FXD
Aug 17, 2014 01:56 AM
tmanbuckhunter
EVO
Feb 4, 2014 09:06 PM
Demonsmasher
Mar 14, 2009 11:43 PM
mroleg
Dec 9, 2008 12:08 PM
