Rocker arm install difficulty
Old Mar 2, 2021 | 07:35 PM
98hotrodfatboy's Avatar
98hotrodfatboy
If you can find a way to bleed down the lifters then you will be able to assemble the rockers and install the shafts... Other than that you'll have to pull the complete rocker plate assembly..
Old Mar 3, 2021 | 05:28 AM
GOGOBECK's Avatar
GOGOBECK
Originally Posted by t150vej
Pulling the rocker lowers has no effect on the heads. If you pull heads you then must pull cylinders for base gaskets....
Thanks, I thought pulling the lower rocker cover also relieved some of the force on the heads... this makes me feel better.
drm1978
EVO
May 10, 2020 09:02 AM
RANGER73
Engine Mechanical Topics
Nov 11, 2018 06:45 AM
timmay17
Jun 16, 2014 12:22 PM
cthowards
May 15, 2011 09:12 AM
ironside67
Ironhead
Jun 8, 2009 02:18 PM
