Jet question.
Old Mar 16, 2021 | 10:07 PM
t150vej's Avatar
t150vej
Yeah, a CV will never have the same split second "right now" blast on a quick throttle twist as other carbs but you can get them close. The needle that's in it will make a lot of difference on low speed throttle response, but options there are very limited these days... It's all relative to everything else and a lot depends on how you intend to ride and good response doesn't have to sacrifice mileage, especially below 60 mph.
I can't imagine trying to tune a CV to open ground pounders on a Dresser but the 13 is a good cam for a heavy bike. Do a 48 at about 2 turns as mentioned and go from there, shouldn't need more than 1/4 + or - to get you close.
Old Mar 18, 2021 | 08:16 PM
LQQK_OUT's Avatar
LQQK_OUT
What needle are you using?
Old Mar 21, 2021 | 03:14 PM
Glasley's Avatar
Glasley
1st Gear
I’m using the stock needle. Ok so I changed to the 48 and left the 180. It dose have what I think it needs but since I’ve started this change from the quicksilver to a cv it can be cold or hot and it shuts off not while idling but in gear I can pull in clutch and fire it back up.it maybe a diff issue Other then this it runs great. Thank you guys for all your info on this.
Old Mar 21, 2021 | 06:23 PM
Yankee Dog's Avatar
Yankee Dog
Also can't hurt to try a 185. You might be pleasantly surprised.
Old Mar 22, 2021 | 09:08 AM
GOGOBECK's Avatar
GOGOBECK
Originally Posted by Glasley
it can be cold or hot and it shuts off not while idling but in gear.
so, what you’re saying is; motoring down the road, it cuts off when you close the throttle?
If that’s the case, I think it’s either a needle jet issue or the slow jet adjustment screw setting. You might try turning the adjustment screw out 1/2 turn, then another 1/2. If that doesn’t solve the problem you might want to change the needle or needle jet.
Old Mar 22, 2021 | 02:13 PM
LQQK_OUT's Avatar
LQQK_OUT
Have you tried using the 1988 1200 Sportster needle?
HD Part Number: 27094-88
27094-88
http://www.nightrider.com/biketech/hd_cv_mods.htm
http://www.nightrider.com/biketech/hdcvcarbappendix.htm
Chopper Nate
Carburetor Related
Sep 10, 2019 09:17 AM
Ridetard
Mar 28, 2009 05:56 PM
Ridetard
Mar 27, 2009 10:06 AM
boxcar
Exhaust System Topics
Jun 29, 2007 09:40 PM
Jip
May 31, 2006 01:18 PM
