Clear torque specs for FXRs
Old Mar 15, 2021 | 10:08 AM
FXREVO87's Avatar
FXREVO87
Stage I
Default Clear torque specs for FXRs
Hey there–
I'm working on an '87 FXR rebuild and am wondering if anyone has a clear torque spec sheet for Big Twins? I've got the service manual which lists specs based on bolt size, but not for each bolt location like newer Harley manuals do. Was just curious if there's an easier guide out there or if I just need to pull it together lol.
Thanks!
Old Mar 15, 2021 | 10:41 AM
t150vej's Avatar
t150vej
If it's the HD Factory Service Manual, you have to go to each individual repair section to the assembly portion to find "special" torque values for what part you're working on. If it's some other brand of manual, I can't help you.
Axles, front pulley nut, compensator nut, head bolts, engine case bolts/nuts, pinion nut, clutch hub nut, transmission shaft bearing nuts are the main ones that come to mind.
Otherwise, most everything is standard torque values for grade 5 fasteners.
mile hi
Sep 7, 2017 07:14 PM
priceamp
Ironhead
Aug 12, 2014 10:09 PM
tribalfxr
Nov 6, 2009 08:10 PM
indyjeff
Sep 30, 2007 09:52 PM
HDF Tech
General Topics/Tech Tips
Dec 12, 2005 07:52 PM
