Trans issue?
Old Mar 21, 2021 | 07:21 PM
Abandoned's Avatar
Abandoned
Default Trans issue?
Just did a few suspension upgrades on my 93 ultra classic this weekend and when I went to take it out for a ride today I noticed a different issue. While in the garage for the suspension stuff, I did a fluid change and swapped out the non working enrichener (choke) cable.
I started up the bike this morning and let it warm up in the garage for about 15 minutes. I noticed that the idle was a little high about 15-1700 rpms, so I adjusted it slightly and brought it back down to about 1000. While adjusting that I noticed that there was about a 4” circle of trans fluid on the ground underneath the bike. Upon further inspection, thinking that maybe the drain plug was not seated all the way, I found that it appears the fluid came from the vent hose that come out of the top of the trans and bends down behind the inner primary by the starter. The hose and the inner primary were wet with fluid in a clear path.
my first question is what could cause this? Second question is what’s the fix. I know there shouldn’t be any pressure in the trans so it should be just blowing out but what could be the issue? I believe I put the correct amount of fluid in to fill it and now it is sitting at the add level on the stick while sitting on the jiffy stand. Any help would be great.
Old Mar 21, 2021 | 07:33 PM
mike131's Avatar
mike131
If you have the correct amount of fluid in the tranny according to HD service manual it shouldn't come out of vent, make sure there is no moisture in transmission fluid which there shouldn't be if you just changed it? , more often its transmission seal leaking and splashing oil up there. In some cases the engine crank seal can leak pressurizing the primary passing threw the center hole in the transmission main shaft into the transmission thus pressurizing the transmission
Old Mar 21, 2021 | 07:39 PM
mike131's Avatar
mike131
How many oz of oil did you put into the transmission? no leak before fluid change? how much fluid came out of transmission when you drained it?
Old Mar 21, 2021 | 08:06 PM
Abandoned's Avatar
Abandoned
I put just under a quart in it. I believe the manual calls for 22-28 oz’s? Something like that. So it was just under a quart. Which was about what I had pulled out of it when I drained it. All the fluids seemed right when I drained them. Nothing had less or more than it should. At least not noticeable at the time.
Old Mar 21, 2021 | 08:09 PM
Abandoned's Avatar
Abandoned
i did not notice any moisture in the fluid when I drained it out. The bike has been sitting for a couple months while I was collecting all the parts to get it all back together.
anyway to test for any of those you mentioned? Without ripping the whole thing apart at least?
Old Mar 21, 2021 | 08:11 PM
mike131's Avatar
mike131
That being the case, Id lower the level a little, if you have like 28oz in her try like 22oz and see if your leak goes away some do like a little less
Old Mar 21, 2021 | 08:12 PM
mike131's Avatar
mike131
What did you use for oil?
Old Mar 21, 2021 | 08:21 PM
Abandoned's Avatar
Abandoned
i can try that.
Old Mar 21, 2021 | 08:33 PM
Abandoned's Avatar
Abandoned
Mobil one 75w90
Old Mar 21, 2021 | 09:30 PM
rizzo's Avatar
rizzo
At the shop we only fill to 22 oz. on a trans service. It keeps venting and drips to a minimum.
