Wrapping the headers
Old Apr 2, 2021 | 03:20 PM
GOGOBECK's Avatar
GOGOBECK
Default Wrapping the headers
I’m gonna wrap the headers with “natural color” wrap, that I bought on the cheap.
It came with SS tie wraps, like 12, but I may use clamps at the heads and the expansion joint. How far apart should there be a tie wrap?
I see they sell some kind of sealing spray, that folks seem to like, I’m assuming it has some adhesion properties. I don’t see it in clear or natural.
Never done this, and the wrap didn’t come with any instructions.
Any tips will be greatly appreciated
Old Apr 2, 2021 | 03:27 PM
TriGeezer's Avatar
TriGeezer
I only used the tie wraps at the start and end. But, mine wasn’t on the cheap.
YMMV...
Old Apr 2, 2021 | 05:18 PM
Dehammer's Avatar
Dehammer
I'm not a pro but this is what I've done and I've only used 2 inch black. It is easier to do pipes on the bike than off and on a dolly or table.
Use thick mil rubber gloves, soak the wrap, begin from end to front, clamp it, keep it tight and smooth, then clamp the end.
Those stainless zip ties are weak, a hose clamp works better, a wire clamp is best if you have the tool. I've never used a spray. I just expect it to look like **** after a while and wreck the pipes.
There is a solid argument for not wrapping you might want to read up on. I wrap areas that burn me. I like the wrapped look when it's done right.
Old Apr 2, 2021 | 05:39 PM
GOGOBECK's Avatar
GOGOBECK
Originally Posted by Dehammer;[url=tel:19840922
19840922[/url]]I'm not a pro but this is what I've done and I've only used 2 inch black. It is easier to do pipes on the bike than off and on a dolly or table.
Soak the wrap... in water I assume?
The hear shields for these pipes are unobtainable... so ima wrap ‘em
Old Apr 2, 2021 | 05:47 PM
TwiZted Biker's Avatar
TwiZted Biker
Like been said it will trash the pipes under the wrap. Pick your poison....
Old Apr 2, 2021 | 06:01 PM
Dehammer's Avatar
Dehammer
A real biker uses urine but water would work fine. I let it soak in a bucket until it's saturated. It'll tighten up on the pipe when it dries.
Heat shields are unavailable on some of the older bike pipes. Supertrapp FXRs being one.
jcallesano
Jul 1, 2013 07:19 AM
VirgeB
Nov 4, 2011 07:22 AM
leohd
Sep 5, 2010 11:04 PM
strich
Apr 12, 2008 09:01 PM
Sgt Rock
Mar 25, 2008 08:51 PM
