Primary Leak.
Old Apr 7, 2021 | 10:32 PM
OLD 96's Avatar
OLD 96
Default Primary Leak.
1995 Road King. Figured it might be primary gasket. Replaced gasket. It is leaking more now than before. It is coming from primary. Judging by the oil. Been chasing this leak. I think it is narrowed down to a leak between inner primary and engine case. Oil is on the lower frame rail which is inboard of the outer primary. As you all know. Dammit. **** ain't never easy.
Old Apr 7, 2021 | 11:03 PM
daven9113's Avatar
daven9113
If you are pretty sure it's primary fluid, then you might have a bad inner primary bearing seal. The inner primary bolts that connects IP to engine and tranny can also leak, so a light RTV on the bolts upon reassembly will take care of that. You should also replace IP to case o-ring too.
Old Apr 7, 2021 | 11:30 PM
OLD 96's Avatar
OLD 96
daven9113. Thanks for the input. Yeah. The oil leak after replacement of primary gasket is definitely coming from the primary. Fresh oil. I will replace all that you mentioned and more. If needed. My Panhead does not leak that much.
Old Apr 8, 2021 | 08:23 AM
daven9113's Avatar
daven9113
Very nice Panhead for sure. I probably have the same primary leak, but I'm just too lazy to take all that off just to fix a little leak. Some guys just can't stand any leaks, and I can understand that. When the IP has to come off for some other fix, I'll do that. Normally, it the shifter shaft seal that starts leaking and that's when folks go in that deep. I see you have a Panhead, Shovelhead, and Evo...you are living the dream.
Old Apr 8, 2021 | 02:25 PM
OLD 96's Avatar
OLD 96
It is a task that I am not looking forward to. The leak has steadily gotten worse to the point that I have to deal with it. Thanks.
Old Apr 29, 2021 | 08:55 PM
OLD 96's Avatar
OLD 96
For any one that is keeping up. I have pinpointed the source of my leak. After spraying with Gunk and brake cleaner fluid to thoughly clean all under neath engine and primary. Jacked up on my stand and put piece of card board . Leak is coming from inner primary and engine case. Well That sucks.
Old Apr 29, 2021 | 09:25 PM
OLD 96's Avatar
OLD 96
I finally pinpointed the leak. Between the inner primary and the engine case,. Sounds like a lot of fun.
Old Apr 30, 2021 | 04:28 AM
Yankee Dog's Avatar
Yankee Dog
Sounds like the large O-ring at the stator area?
As mentioned, double check the bolt holes for the chain adjuster bolts. Those are drilled thru the inner cover and are siliconed from the outside by the factory. Had a leak at the bolt on mine, and I just cleaned it with brake clean, a small wire brush, and reapplied a dab of silicone. All from the outside of the inner cover. Held up fine.
Old Apr 30, 2021 | 11:28 PM
OLD 96's Avatar
OLD 96
Yankee Dog. Thanks for the advice. The leak is at the lowest point of where the inner primary and the engine meet. I am never so lucky. Just going to have to bite the bullet and pull it down and do it right. Not my first rodeo. Thanks to all for the advice and input. Will be calling for ya'll in the future for your knowledge and advice. Keep the shiney side up and the rubber side down.
Old May 3, 2021 | 03:40 AM
mplecha's Avatar
mplecha
Removing the inner primary isn’t as bad as you think. I’ve done it many times. You can have it off and back on in a couple of hours.
