Ok I kind of want to cut some off the pipes. Never been a fan of straight long pipes. If I hack about 8 off the top one...should I measure it and make the front pipe the same length as the rear. Giving it a staggered look?
Do what you want with it. Ideally, all header lengths should be the same. You are starting out with the front longer than the rear. These are not exactly hyper performance bikes, so cut it however you want it.
I had a set on my last Fatboy. Im wondering if that will help with the deep droning noise this exhaust makes.
Only one way to find out, and you can tune the lollipops by turning them. If you can weld, then homemade is the way to go, if not, you can still make them by using anything from thumb screws to eye bolts with a couple washers, of give DK a call.
Be careful if you make your own lollipops. I used washers that were too large. It caused my bike to overheat and cooked the ignition. Now I have to spend $200 to fix my 50 cent mod.
