Sturgis prep: getting a 94 wide glide to go 5k mi in 2 weeks
Old Jul 8, 2021 | 10:47 PM
itsdug's Avatar
itsdug
Just do it!
Old Jul 9, 2021 | 06:13 AM
Architect's Avatar
Architect
Same amount of effort to replace the bearings as to repack, and they are not expensive. Get the wheels off, new seals and bearings and good quality grease, one less thing to worry about.
Cam change is up to you, but sounds like a lot of work considering your time frame.
Handlebars, don't bother. It is not the 70"s anymore, cops do not care about pulling guys over for high apes anymore, and yours are not even all that high. Last time I heard about someone getting pulled over for apes was about 1991 in NYC. Save the time for more critical projects.
And I agree with others, get it done fast, then try and get a bunch of mile sort the bike close to home to work out any gremlins.
Good luck.
Old Jul 9, 2021 | 06:43 AM
Yankee Dog's Avatar
Yankee Dog
Ooops, double post
Old Jul 9, 2021 | 06:45 AM
Yankee Dog's Avatar
Yankee Dog
Good luck.
As far as the bearings, there is a little bit more to it... press out old races, press in new races, mount and measure bearing play, use appropriate shims to get proper spacing/play...
Old Jul 9, 2021 | 06:46 AM
Dr.Hess's Avatar
Dr.Hess
Regular spoke wheels will have a tube. Don't worry about the regulator. Repack the bearings and go. Use HD wheel bearing grease.
Old Jul 9, 2021 | 07:19 AM
mike131's Avatar
mike131
I'm with Architect, If I'm going to pull it apart I'm going to replaced the bearings and races, do you know if they were serviced correctly in the past? I just don't trust just visually inspecting a wheel bearing on a motorcycle, Yankee Dog is exactly correct it is a little more work but for me I like to have the extra security, but I maybe a little bearing paranoid! Timkens are great bearings, all I try to use at work but I do have my fair share of failures with Timkens not so much on bikes but on vans and especially trailers not really trucks too much any more, most of them have went to hub assemblies which also fail, and yes the trailers most of the failures are probably because of the simpletons at work jackknifing them with a heavy load and putting a extremely high side load on them
Old Jul 9, 2021 | 07:57 AM
Ironhandjohn's Avatar
Ironhandjohn
Good luck.
I was going to ask about where OP thinks he’s going to get hassled for his handlebars?
Old Jul 9, 2021 | 08:09 AM
Architect's Avatar
Architect
I wouldn't bother changing races unless I saw deterioration, pitting, rust or something else wonky. I would not hesitate to drop new bearings in to the original races if they look solid, just sayin'.
Old Jul 10, 2021 | 07:43 PM
carlgrover's Avatar
carlgrover
Don't forget to pick up a new set of oil seals when you service the bearings.
carl
Old Jul 11, 2021 | 12:41 PM
evotrike's Avatar
evotrike
Defenitely full change on wheel bearings. My front ones lunched on my 98 Ultra on a 100 mile trip with 48k on it...limped home at 45mph.Good insurance. Ken
