saddle bag replacement
Old Jul 30, 2021 | 07:54 AM
gnafin's Avatar
gnafin
Default saddle bag replacement
i remember way back like in 2010 someone converted a 1984 flhtc with the saddle bags to new bags and also moved the battery. does anyone remember it?
Old Jul 30, 2021 | 08:55 AM
98hotrodfatboy's Avatar
98hotrodfatboy
"1894" Were the bags from the "Pony Express"??? Lol.. I know it's Friday....
Old Jul 30, 2021 | 09:23 AM
gnafin's Avatar
gnafin
ya i did not check. thanks.
Old Jul 30, 2021 | 09:54 AM
WP50's Avatar
WP50
Omaha did his 90 FLHT a few years ago.
I know it.s been done by a good many just not sure about a 84 model
WP
Old Jul 30, 2021 | 10:57 AM
98hotrodfatboy
There was another thread about I believe an early 80's FL with bags.. I'll see iff I can find it.. was a few years ago..
Not finding anything...
Old Jul 30, 2021 | 12:01 PM
t150vej's Avatar
t150vej
Moving the battery is the hard part. If I remember, 0maha ended up using a smaller lithium battery (they are very expensive) mounted under the seat. Been a long time, but seems like someone did one with a smaller AGM battery but it was tight.
Otherwise all you need are the bags, and a different right side saddlebag guard. You can cut the battery box off what you have, but those guards are getting scarce. I would look for a used 49202-93 guard for '93 thru '96 rather than destroy a piece of history... but that's just me.
You will also need to find a different passenger handrail. Yours is too wide for the lids to open with the newer bags. Later ones are swept upward and more narrow. I'm too lazy to look up the numbers of what will work. Just be careful, as some of the later ones used a single bolt mount on the rear of the seat whereas yours mounts to that handrail with 2 bolts. And the rail also mounts with one bolt to the TourPak mount.
You'd just need to look at pictures of what's for sale to find what it'd take on that. Come to think of it, you can't use the later more narrow handrail with your original seat. The passenger seat is too wide, but if you have an aftermarket set, it would work.
Old Jul 30, 2021 | 04:19 PM
EVOrider's Avatar
EVOrider
I thought Graham moved his battery to under the seat on his 1990 when he put the larger tank installed.
Old Aug 5, 2021 | 02:34 PM
Mountainkowboy's Avatar
Mountainkowboy
I did it to my 89, batteries are MUCH better now. I will do it again eventually.
sdregi
Nov 13, 2016 11:03 PM
CVO SG
Jun 12, 2016 04:08 PM
Papa Joe
Nov 9, 2014 08:34 PM
keno
Jan 22, 2010 10:12 PM
TRUBRIT
Apr 7, 2007 10:56 AM
