oil soaking air filter
Old May 22, 2022 | 11:10 PM
sparky0496's Avatar
sparky0496
Default oil soaking air filter
Hey all I'm back.... Just been lurking and learning lately from all of you. Picked up a 98 Electra Glide ultra classic this winter, have a front rocker box leak i can fix that. My big question is there seems to be a good amount of oil blow by into the air cleaner anyone have a good idea how to route it so all that oil doesn't make its way back into engine? Or is there something wrong that i am missing??? Thanks once again in advance.
85 Tour Glide Classic
98 Electra Glide Ultra Classic
Old May 22, 2022 | 11:24 PM
brakeless's Avatar
brakeless
Make sure the umbrella valves in the rocker boxes are good. And then vent it to atmosphere! Lots of videos on that.
Old May 23, 2022 | 05:12 AM
IronAss's Avatar
IronAss
Just do a youtube search on external oil breathers and you'll have enough to keep you busy watching vids all day.
There are many options form cheap do it your self to fairly pricey if form over function is your thing.
ETA.. As brakless said, Check your umbrella valves. I too am getting blow by on the front and am going to be replacing them.
Old May 23, 2022 | 05:28 AM
FreedomRider's Avatar
FreedomRider
As mentioned change the umbrella valves but most of the mess can be corrected by not filling the oil to the full mark ... fill to half way between the marks
I use 3 quarts in my 1996 and it has not cause a problem in 157k miles ... Harley's are a dry sump system ... the motor only has around a cup of oil in it when running, the rest is in the pan ... having a little less in the pan doesn't hurt anything and it keeps oil from blowing out the breathers
Old May 23, 2022 | 05:34 AM
Bass Player's Avatar
Bass Player
Vent to the outside and forget it.
Old May 23, 2022 | 06:59 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The latest OEM rocker box gaskets are as good or better than anyone else's.
The Harley rocker box gasket kit will include the butterfly valves.
Old May 23, 2022 | 07:34 AM
sparky0496's Avatar
sparky0496
Thanks guys for the advice will be tearing into this tonight for rocker gasket replacement.
Old May 23, 2022 | 07:36 AM
sparky0496's Avatar
sparky0496
so just run a hose down under the pan and call it a day then like I did on my 85???
Old May 23, 2022 | 11:35 AM
Bass Player
Yup, there you go.
Old May 27, 2022 | 07:45 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Yup, there you go.
No, not the same as an `85, and not the same solution.
