Points conversion?
Old Jun 29, 2022 | 09:53 AM
Racepres's Avatar
Racepres
^^^ Most Carburetor Problems... Are Actually Something Else
And these
If your talking about the cam position sensor, Standard Motor Products makes a very good one.. MC-SPA2. I've been using them for years...
https://www.denniskirk.com/standard-...rd/2000238.sku
Are also available at better Automotive Stores!!! NAPA in my part of the Rhubarb Patch
Oh... Learn to Depin and Pin those H-D connectors...a skill that will serve over and again!!!!
Old Jun 29, 2022 | 09:58 AM
Dehammer's Avatar
Dehammer
I grew up on points. When I got my first Evo I bought a set for when the electronics failed. I still have them in a box 25 sum years later. The electronics are easier to take care of. I like easy.
I even have a Morris Magneto around here somewhere. Points are easy to work on that.
The only ignition I had utterly fail was a piece of **** Crane in the cone.
I still don't trust the computer on my TC. Electronics and a carb is a simple combo best solution for a guy like me.
Old Jun 29, 2022 | 10:11 AM
IronAss's Avatar
IronAss
Originally Posted by Racepres;[url=tel:20691738
20691738[/url]]
I assume you’re referring to the round one coming off the sensor? If so, I’m open to any tips on it or which type of tool helps.
Thanks.
Old Jun 29, 2022 | 10:47 AM
RHPAW's Avatar
RHPAW
Agreed. I think they were intended for show bikes.
Old Jun 29, 2022 | 03:31 PM
Racepres's Avatar
Racepres
Thanks.
My best tool to date, is a small screwdriver looking thing, that is rounded and curved... and works a Dream... Will look for picture
once you have the tools...any HD connector (maybe Not new stuff) is fair game..
this one looks most like my set
https://www.summitracing.com/parts/p...SABEgJamPD_BwE
This also
https://static.summitracing.com/glob...-40011g_xl.jpg
Old Jun 29, 2022 | 04:03 PM
IronAss's Avatar
IronAss
Originally Posted by Racepres;[url=tel:20692359
20692359[/url]]My best tool to date, is a small screwdriver looking thing, that is rounded and curved... and works a Dream... Will look for picture
This also
Thanks so much for that!
Old Jun 29, 2022 | 04:51 PM
98hotrodfatboy's Avatar
98hotrodfatboy
I don't see any "Point" in going backwards..
Old Jun 29, 2022 | 05:46 PM
Tired's Avatar
Tired
Maybe the timing for it just isn't now? No need to dwell on it anyway.
Old Jun 29, 2022 | 06:27 PM
daven9113's Avatar
daven9113
I like to keep my plate simple by condensing the back-up ignition setup in my saddlebag.
Old Jun 30, 2022 | 07:37 PM
carlgrover's Avatar
carlgrover
After speaking with a local guy I trust I decided to just replace the sensor.
He told me with the high humidity here, almost everyone that his shop deals with that have gone to points complains of issues with the moisture which is something I hadn't thought about.
When I had my Pan and lived in Seattle rain was an issue but that was with the OEM distributor that was prone to leaking. .
I've run my shovel on points in Alabama summer rain storms and had no troubles.
carl
