Turn signal module?
Old Jul 19, 2022 | 03:24 AM
IronAss's Avatar
IronAss
Default Turn signal module?
Will removing it cause anything else to screw up?
I'm thinking it shouldn't but I seem to be wrong more than right nowadays especially when it concerns anything the uses electricity.
Why I want to remove it is really not part of this conversation.
It is on a 93 Softail.
Old Jul 19, 2022 | 03:57 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
I think it contains the bank angle sensor so you will lose auto engine off if you drop your bike.
It might stop the bike from starting.
Old Jul 19, 2022 | 04:08 AM
IronAss's Avatar
IronAss
That is the type of thing I need to know.
Can anyone confirm this?
Old Jul 19, 2022 | 05:26 AM
V-Twins & Bowties's Avatar
V-Twins & Bowties
93 doesn't have a bank angle sensor. At least my 93 FLHTC doesn't and it's stock.
Don't ask how , but it's been tested.
Old Jul 19, 2022 | 05:33 AM
RANGER73's Avatar
RANGER73
You could just unplug it and find out. No?
Looking at the wiring diagram, nothing will be affected except the blinkers won't work.
Old Jul 19, 2022 | 05:46 AM
98hotrodfatboy's Avatar
98hotrodfatboy
You can take it out if you want to strip your bike down.. It will not affect anything, including ignition, nothing. As for Bank angle sensor, they never had one but in the original cam position sensor there's what is called an altitude switch.. If you do drop your bike it will shut the motor off, it's built into this CPS other than that you'll be fine..
Old Jul 19, 2022 | 06:03 AM
IronAss's Avatar
IronAss
Originally Posted by V-Twins & Bowties;[url=tel:20725370
20725370[/url]]93 doesn't have a bank angle sensor. At least my 93 FLHTC doesn't and it's stock.
That’s what I think. I believe all the other **** is part of the TSSM which is later.
Like I said though, what I think and what actually is can be two very different things.
Old Jul 27, 2022 | 12:23 PM
IronAss's Avatar
IronAss
I’ve got tanks off and not seeing anything that resembles what is shown in the parts book diagrams.
Is it what the black rubber cover is on maybe?
Old Jul 27, 2022 | 02:36 PM
Trumpet's Avatar
Trumpet
nevermind
Old Jul 27, 2022 | 02:49 PM
IronAss's Avatar
IronAss
Before I removed the turn signals, they would self cancel.
That causes me to assume it has to be on the bike somewhere.
There are only two wires coming out of the headlight so I’m stumped.
