Neutral light off/flicker?
Old Jul 23, 2022 | 10:52 AM
johnod's Avatar
johnod
Default Neutral light off/flicker?
97 FLHTCUI
The neutral light stopped coming on in neutral, for a couple of days , and now seems to be back on ( in neutral) what , where should I check or look for?
Thanks
Old Jul 23, 2022 | 10:56 AM
Mountainkowboy's Avatar
Mountainkowboy
The switch is in the top of the trans, probably a poor connection there. It works by ground, if you ground the wire, the light comes on. I would start at the switch and go from there.
Old Jul 23, 2022 | 11:04 AM
johnod's Avatar
johnod
Thanks, that's what I'll do.
It does act like a poor connection.
Old Jul 23, 2022 | 12:30 PM
Dano523's Avatar
Dano523
Quick down and dirty.
Top back side of the trans cover, you going to see this,
Amazon Amazon
With this the connector on top of it,
Start by checking the connector, to make sure it's good to the wire and not a problem there.
With it off, pull the switch, and body connected to ground, to see if the switch is working next by pressing the ball in, and letting it snap back out.
Note to check the connector to wire, just ground it out to the case as well.
If switch and wire is good, keep in mind that what is allowing the switch to work, is the end ball rides in a groove in the shifter drum, and its the detent in the slot that activates the switch. So the washer you see in the the first link, is used to space the sensor off the trans cover the correct distances to make the switch work. If nylon washer in play, and it sensor are over tightened (or someone replace it with one too thick), has the sensor not located off the cover against. the drum slot the correct distance, and will cause problems (hence may just be a $.10 nylon washer that may need to be replace, or the sensor just needs a good contact cleaner douching to clean it up so it works correctly again).
Worst case, may have to pull the shifter cover to make sure that the drum bolts are still tight.drum detent not a problem, and why the drum is not activating the switch correctly.
Old Jul 23, 2022 | 01:34 PM
johnod's Avatar
johnod
https://www.amazon.com/Standard-Moto.../dp/B000WJFCDE
Thanks will check it out.
Old Jul 23, 2022 | 03:27 PM
flhchaz's Avatar
flhchaz
I had the same issue on my '97. Took the switch out cleaned put it back together with dielectric grease on the connection and has been fine since.
OP- How has it been running since the carb conversion?
Old Jul 23, 2022 | 03:33 PM
johnod's Avatar
johnod
Been running great, very happy with it. I think I even get better mileage.
Thanks for all your help with that.
Old Jul 23, 2022 | 08:31 PM
WBB1's Avatar
WBB1
Not sure what bulb the 97s use but check the connection there too.
Old Jul 24, 2022 | 03:32 PM
johnod's Avatar
johnod
Cleaned the connector and post on switch, seems to be working well.
Thanks all.
dwe.61
39
Nov 27, 2015 12:03 PM
yso191
Sep 13, 2009 09:09 PM
RaoulDuke
Electrical/Lighting/Alarm
Apr 26, 2009 12:43 AM
beth1234
Aug 5, 2008 11:48 AM
Jimbo192
Sep 23, 2006 07:22 PM
