1984(early) FLHTC oil lines
Old Aug 16, 2022 | 11:48 AM
gnafin's Avatar
gnafin
Default 1984(early) FLHTC oil lines
1984(early) FLHTC oil lines.
what are you all using to replace the oil lines for this old bike?
Old Aug 16, 2022 | 12:50 PM
WBB1's Avatar
WBB1
Just normal fuel line from any auto parts store.
Old Aug 16, 2022 | 01:35 PM
Dr.Hess's Avatar
Dr.Hess
Stainless braided. I bought a roll of Russell brand and used that. I would not use fuel line for oil. They are not all compatible and some will turn to mush from the oil. Oil line is cheap enough and available anywhere.
Old Aug 16, 2022 | 01:45 PM
Stiggy's Avatar
Stiggy
If you choose R-10 (submersible, gasoline rated,) neoprene, you won't have to worry about the lines deteriorating (but the stuff is pricey, like $10 / foot if I recall.) Available at NAPA.
Old Aug 16, 2022 | 02:17 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
SAE J1019
Rated for 300 degrees continuous.
I have also used SAE 30R9 hose, and it never deteriorated.
Old Aug 16, 2022 | 08:46 PM
86glider's Avatar
86glider
Would like to know how to get the tight turns without kinking?
Old Aug 16, 2022 | 08:52 PM
Dan89FLSTC's Avatar
Dan89FLSTC
I`ve been poked a thousand times by frayed braided oil and fuel hose as an aircraft mechanic, I came to hate the sight of it.
Thankfully in the modern aviation world it has gone the way of the dodo bird. There is no advantage in using it on a motorcycle.
Old Aug 17, 2022 | 07:44 AM
Racepres's Avatar
Racepres
Amen...
And it gnaws into/thru anything touching it.
Old Aug 17, 2022 | 08:35 AM
jonnycando's Avatar
jonnycando
turn the spigots outward if they aren't already so they aren't cramped against the transmission and they may show a mild kink when new but will soften up with use.
Old Aug 17, 2022 | 10:24 AM
gnafin's Avatar
gnafin
thanks, i will have to go to napa and look for the good hose.
