Another cam question
WP.
I was planning on replacing the rocker cover bolts with hex heads. Theyre much easier to remove than the allens that are there now in the fxr frame, but I couldn't find any and didn't want to leave the house for them. I have a wrench I cut down to fit the rear. It helps, but what a pita that is.
I got the rocker covers off and pulled the pushrods. The gear case cover came off with a few whacks of a mallet. with the spark plugs out and the trans in 5th, I turned the back wheel and lined up the timing marks.
The cam and breather came out. The plastic breather had a little scoring, but I didn't think it was too bad. The bore had some as well. I replaced the plastic breather with an S&S reed valve.
Pressing the oem gear off the N cam was pretty simple. I ended up marking the gear with a sharpie and pressed it onto the new cam. I was pleased that I got it just about perfect on the first try. Next task was to replace the inner cam bearing. I have a blind hole puller I borrowed from auto zone about 15 years ago when I changed the bearing in my Twinkie Fatboy. I didn't realize id forgotten to return it until the last time my family moved. Oops.
The old bearing came out pretty easily. I used the old cam and gently tapped the new bearing into the case with a dead blow. It took me a while to set the end play on the cam, but I ended up at .013, and I'm happy with that.
The gear case went back together.I replaced my lifters with a new set of Johnson hy-lifts, reinstalled the pushrods and rockers and called it a day. I'll finish up the ignition and timing, tomorrow.
I didn't see it in any of your other pics...
Another thing I was wondering about. My 94 had an eared washer behind the cam. That bike had an ev27 when I got it. This engine is a 97 and just had a round washer behind it. Is there a reason for that change? I was surprised to see the ears were gone.
My 94 did not .
Thanks for the info on the SS reed valve.
Eager to find out how you like the 3010. Your mileage should improve also.
