Front tube length?
Old Sep 3, 2022 | 04:02 PM
richard567's Avatar
richard567
Default Front tube length?
I'm getting conflicting measurements from sites I'm trying to buy from.. one says stock length is 24 1/4, another says 22 7/8.. 1989 flhtc.. tryin to put new tubes on.. any help as to what the length really is?
Old Sep 3, 2022 | 04:12 PM
t150vej's Avatar
t150vej
20-7/8"
45827-84
Old Sep 3, 2022 | 04:55 PM
SparkyD's Avatar
SparkyD
Inner tube? Down tube? Fork tube? Push rod cover tube?
Old Sep 5, 2022 | 07:38 AM
richard567's Avatar
richard567
Default Wise guy huh
Fork tubes idiot
Old Sep 5, 2022 | 08:01 AM
smitty901's Avatar
smitty901
have the Does it have factory tree or a raked one.
Old Sep 6, 2022 | 08:30 AM
Racepres's Avatar
Racepres
Without the Bike Model... No Chance...
RubberGlide is Longer than Softail ... which is different from Wide Glide.. not as Easy as NarrowGlides.. Unless you count Sportsters... which Vary Widely!!
If Stock... the free length of the Spring will tell most about Tube Length..
Do Not believe the Ebay seller that tells ya they are all the Same... Typical Asshat..
Old Oct 3, 2022 | 07:42 AM
richard567's Avatar
richard567
Default I
sAid it's a FLHTC
Old Oct 3, 2022 | 08:05 AM
Racepres's Avatar
Racepres
sAid it's a FLHTC
All Rubberglide baggers I have fooled with have Longer Tubes..I will Measure the tube itself if helpful
but
the proper measurement is top (neck bearing) of bottom tree, to axle..
Old Oct 4, 2022 | 08:22 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Just the tube itself according to Frank's Forks for FLH 84-99 is 20.25"..
24.25 is FX 's and FLS's are 22.25"
Old Oct 5, 2022 | 08:06 AM
Racepres's Avatar
Racepres
Shovelhead stuff is fairly Easy...Evo's... not nearly so.. tho that 22.25 is what I get when measuring (most) Touring models..
Softails?? vary wildly..
Like FX's.. FXE is Not FXS is Not FXD
