Brake wiring on 85 FXWG
Old Oct 14, 2022 | 08:16 AM
nutsandbolts5212's Avatar
nutsandbolts5212
Default Brake wiring on 85 FXWG
Hey guys, I'm finishing the wiring on the 85 FXWG rebuild and I have one question: When the breaks are applied, front and rear, the tail lamp goes out and the rear signal lamps light. Is this correct for this era bike? Thanks
Ride safe!
Old Oct 14, 2022 | 08:45 AM
Racepres's Avatar
Racepres
Ride safe!
The One here is Not together ATT. But... I'm gonna say No
All Mine, the Brake Lights are totally Independent of other lighting...Stock? or one of them Magic Boxes???
Old Oct 14, 2022 | 09:10 AM
nutsandbolts5212
I'm going to check the bulb today.
Ride safe!
Old Oct 14, 2022 | 09:27 AM
Racepres's Avatar
Racepres
Ride safe!
Bulb???
Bulb socket maybe...Again, Stock Wiring??? or one of them "boxes"
Old Oct 14, 2022 | 09:57 AM
Dr.Hess's Avatar
Dr.Hess
No. With the BRAKE applied, both the tail and brake light filaments should be illuminated and nothing at all should happen to the turn signal lights. One of them "boxes" is the best guess here.
Old Oct 14, 2022 | 11:31 AM
nutsandbolts5212
Yeah, I figured as such. Thanks for the replies, gonna get troubleshooting.
Ride safe!
Old Oct 14, 2022 | 11:43 AM
nutsandbolts5212
When you guys say "boxes" or "magic box" what do you mean? Everything plugs into the terminal block.
Ride safe!
Old Oct 14, 2022 | 11:50 AM
Dr.Hess's Avatar
Dr.Hess
An aftermarket brake light/turn signal controller. Later models had one from the factory that goes out and is unobtainium. An earlier model such as your 85 would not have come with one.
Old Oct 14, 2022 | 12:10 PM
nutsandbolts5212
Ok, thanks.
So I took one of the turn signal lamps and hooked it up as the tail lamp. Works like a tail lamp should so I'm going to take a look at the tail lamp itself, maybe a bad connection at the bulb or might buy a new unit altogether.
Ride safe!
Old Oct 14, 2022 | 12:17 PM
nutsandbolts5212
Boy do I feel stupid and sorry for wasting everyone's time. I didn't have the tail lamp grounded and once I did everything worked like its supposed to work.
Thanks for the responses and pardon my rookie mistake. Gonna finish buttoning this all up and check again. I'm about finished with this restoration so look for my other thread once I get this baby started.
Ride safe!
mrhammer2u
Jan 11, 2018 02:19 PM
darryduck
Oct 19, 2012 01:29 AM
dclements0
Aug 9, 2011 11:58 PM
JoeDirte
Oct 14, 2008 09:23 PM
MODCOBRA
Aug 30, 2008 05:12 AM
