I've replaced the seal and spacer on two of my TCs, I believe it is similar, especially on my 01. I don't have enough miles to say for sure. I had to go with eastern performance for the space on my 01,because harley no longer makes them. I have heard of flipping around, I saved them, in case someday it is needed,
I don't know about flipping one on an Evo. They have a lip on one end and I don't think reverse install would be a good idea but never tried it, so can't swear to anything. They only used that particular part number '97-'98 and the very few 2000 Evos they built. The seal is the same on all the Evos and it's been too long - can't remember if the length is different from the '70 thru '96 engines (24002-70) but the lip is a lot thicker on the earlier ones.
Originally Posted by franka
only place leaking is the vent into carb but that is due to oil tank over full.
Yes, but it WILL eventually drain the primary and cause all kinds of problems...
I am talking about the metal spacer, not the seal. I have heard of flipping if there is a groove, so the seal than rides in a new spot. If I had no way to get a spacer I would.
I woiuld beasure fluid in all 3 holes. Make it right, and go for a ride,
There is no flipping around the spacer, it has a raised lip that seats against the bearing..
My mistake then. I watched some video on a pan or knuckle that had one, so I though they all did. Which is also where I got the idea to flip. I also assumed since my 01 has the timken bearing, and uses tools from evos, it was similar , My mistake,
