Ignition Problem
Old May 6, 2023 | 03:28 PM
johnod's Avatar
johnod
Default Ignition Problem
97 FLHTCUI
I changed the cam bearing this winter and a new breather gear, and buttoned it back up
Re timed the existing ignition, Compu Fire 20600, ( single fire) and started it up, just for a few seconds, maybe a minute, as it was up on the lift and not sure how steady that thing is.
Ran fine, I shut it of, and then there was a loud bang, similar to an exhaust backfire, which is what i thought it was.
Anyway now it won't start, I pulled a plug and grounded it to a head bolt, doesn't appear to be a spark, but i will test that again.
Are there any tests that can be done on the Compu fire?
I'll pull the tank so I can test the coil, any other suggestions or advice?
I changed it to a carb several years ago, and I have gas, so it's not a gas problem, which leaves spark.
Thanks.
Old May 6, 2023 | 07:08 PM
t150vej's Avatar
t150vej
Connect a test light (not volt meter) to ground, other end to one of the outer coil primary wires - either the black one or white one. With switch on and cranking starter, you should get a pulsing "light." Switch to the other coil primary wire and check it the same.
If neither give a light, make sure the module is getting power (red wire) as well as the coil which should be a white wire on center post of the coil primary.
Old May 7, 2023 | 09:13 AM
johnod's Avatar
johnod
Thanks will give it a try.
Old May 11, 2023 | 01:04 PM
Fatboy1389's Avatar
Fatboy1389
Check that your carb is still attached to intake seal after the backfire…. I’ve had a carb come loose and just replaced the seals afterwards
Old May 11, 2023 | 05:06 PM
johnod's Avatar
johnod
Got her started today.
I did some more checking since the last post and found I had spark, but it seemed weak, A new battery solved the problem.
I now have a couple of different problems, and will start a new thread, i think I know the answers, but it's good to get opinions from people who know more than me, whom are many.
Thanks for all the help.
Rounders
34
Aug 15, 2022 10:34 PM
Bcoish
EVO
11
Apr 29, 2019 09:09 PM
Daniel Miller
Jul 7, 2015 11:52 AM
Daniel Miller
Jul 7, 2015 09:06 AM
zenwarrior
May 19, 2007 11:21 AM
