Pre-ignition
Old Jul 22, 2023 | 08:12 PM
glidein wide's Avatar
glidein wide
Default Pre-ignition
So what would be the common cause for a sputter or two after shutting her down?
With ignition switch not the kill switch, never use that it's a bad habit for people.
Old Jul 22, 2023 | 09:48 PM
Trumpet's Avatar
Trumpet
Timing off.
Old Jul 22, 2023 | 10:37 PM
TwiZted Biker's Avatar
TwiZted Biker
Or she's getting an air leak, getting some detonation rattle.
Old Jul 22, 2023 | 11:25 PM
Tommy C's Avatar
Tommy C
Low octane fuel will make them diesel like that, especially in hot weather.
Old Jul 23, 2023 | 07:43 AM
johnjzjz's Avatar
johnjzjz
Look at the spark plugs and count the threads that are dark - 3 threads at. The bottom end is the correct heat range for your combo
too hot will cause it to re ignite the fuel still coming in //// but some ignition switches will off and on and off again as your turning it just one click
use the button if it still happens - chase the plugs
Old Jul 23, 2023 | 08:13 AM
downzero's Avatar
downzero
Carbon buildup in the engine can cause that. Don't worry, it's not preignition. If you had that, you'd have parts all over the place and shrapnel in your leg.
Old Jul 24, 2023 | 08:38 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Idle could be too hi as well, combine that with carbon build up and extra heat ( check the heat range like John said..) poor fuel and it'll do it .
Milwaukee Eight (M8)
48
Jun 24, 2022 12:47 PM
LADNAR
Sep 17, 2012 09:46 AM
John7253
Jun 23, 2010 08:41 PM
Corndog
Aug 6, 2008 07:12 PM
kawsakimx6
Jul 12, 2007 01:01 AM
