M8 oil filter ok?
How do you know what process is used in obtaining the filters?
How do you know the aftermarket doesn`t use lowball bidders for the parts used in their filters?
There is a lot more involved in finding subcontractors than simply finding a company that can put in a low bid.
Have you ever heard of an OEM Harley oil filter causing a problem?
The manufacturer says the M8 filter will work on certain EVO models, the reason they can`t be used on all EVO models is because a few models used an oil filter with an oddball thread.
Apples and Potatoes!!!!!
After all that I could Care Less what Others do with their Motorcycle... I run to Manufacturers Specs (at the time of Manufacture) whenever possible... Y'all??? Do Whatever makes ya Feel Good... Won't affect me one Drop...
The oil pump is original and has never been rebuilt, 145,000 miles so far, and it has no problems scavenging the oil and returning it to the tank, through that "too restrictive" filter.
I don`t see any posts on any forums addressing real issues with TC filters being used on Evo engines, but lots of posts about not to use them because oil will blow out the breather.
sorry for the repartition posts above mine refreshed after i posted.
Facts are unavoidable... Shovels and Evos do Not rely on Pressure... only what little pressure which supplies Flow! More restrictive is a Fact of Smaller Micron ratings... Restriction is a Cause of Pressure.
All Facts, that the Pimple faced kid, working for the New MoCo...has No Clue... Take yer Evo to the Dealership for your Next Oil Change, and Service Interval...How's that go????
Or... Keep doin what You are Doing... Working for You...But...Don't make it Right....
On the oil out the breather.... Caused by Sumping... if occurring when running, can Only be attributed to not being able to Evacuate the Bottom end (sump).. The Oil Return...thru the Filter, cooler etc... is Only thing that can Change that... Restrict return flow...oil gotta accumulate someplace..
And now...I step aside...Obviously some need to hear from someone else...I ain't Smart enough!!!!
Original question; M8 oil filter OK (in Evolution Engine). Correct Answer: Not Recommended... All else is Supporting the Recommendation
Now, when they no longer have those filters in stock, we have a conversation. Good luck.
Fitment: Fits Harley-Davidson Milwaukee-Eight 17-later Twin Cam 99-17 And Evolution 99-later (except 08-13 XR). Can be used as an upgrade for any motorcycle that requires Oil Filter P/N 63796- 77A 63805-80A 63812-90 or 63813-90.
I just don't know. I'll stick with the original or the Hiflofiltro equivalent.
As for Lower quality product... maybe in the mid 70's...Maybe... by the '80's the Shovelhead had reached the Epitome.. and even AMF knew it was Dated!!!
So they had already invested Heavily in the Evo to replace it, and of Course...Nova to surpass the entire Industry... or Maybe the Wizz Kids really were All That!!!
yea you know...the Kids that brought us the Twinky...and Reintroduced Planned Obsolescence!!!
Gotta Love the Internet!!!
