1998 Fatboy Clutch Upgrade/ Maintenance
would be pulling the starter apart, to check out the starter clutch assmbly, to either pull is apart clean and relube the one way clutch pack, or just replace it if you don't have the tools to pull ball bearings cleanly without distroying them to get the one way clutch parts in the middle of the gear section.
https://i.ebayimg.com/images/g/RV8AA...6yb/s-l960.png
Hence reason for the starter clutch, is when the engine starts, allows the starter pawl gear to free wheel as the flywheel teeth are moving faster, and so the starter gears is not dragging/ ripping flywheel teeth off the hub gears as it retracting back off the hub gears.
Note the retracting part, since the teeth on your flywheel gear are not ripped apart all the way across, but just half way back on the retracting side of the teeth/not on the pulling engagement side of the pawl gear teeth, telling you you have problems with the starter one way clutch in the starter that is causing the hub teeth damage.
Clutch out of basket, get rear tire up off ground to spin center hub in basket with rear tire, against stationary outer shell that primary chain and engine are holding in place, and make sure that outer front face of clutch basket is not dancing in and out with center hub being spinning. 1/16" to 1/8" of outer hub face dancing in and out of full inner hub rotation, kind of normal, but when your taking 1/2' or more of the outer basket front face dipping in and out as center hub is being rotated, then clutch hub bearing is toasted.
If its not the bearing gone south (even before the point of making noise), then its either bearing no longer seated tram in outer basket socket, or problem with the inner hub not running true as it turning on trans input shaft, with start of teeth spines broken off.
Simply inner clutch hub mats up to input shaft on trans, inner bearing races mates up to inner nub shaft, outer bearing race mates up to outer shell channel, so if problem on inner hub side via broken spines or bend input shaft, then inner hub will not be running concentric in the first place/can check that with dial indicator just spinning the inner hub alone via rear wheel.
If outer shell front face is dancing in and out with it being held stationary via primary belt, as inner hub is spinning concentric on trans input shaft, then problem with either bearing no longer running true between is races in rotation of the bearing, or bearing out race no longer seated tram in outer hub socket isntead.
Bearing is cheap enough to replace if to much lateral slop between races with aftermarket bearing on the cheap, and if problem is bearing no longer seated tram in outer basket channel socket to cause the problem instead, not a hard to fix that problem via lathe and shim, since clip 18 is going to hold the bearing in place in the end;
isntead of having to replace the entire outer shell that is $440 before tax.
https://cimg6.ibsrv.net/gimg/www.hdf...618404e35b.jpg
snip
Blue
If the bearing is not long seating true, then either it is loose in the inner hub or was pressed in wrong to start.
Another thing to note is that inner hubs can wobble some.. The broaching practice is not perfect.
Not sure what you are saying in the last paragraph.. "dancing in and out with it being held stationary"
