Piston orientation?
Old Apr 8, 2025 | 12:41 PM
Mhakalucky's Avatar
Mhakalucky
4th Gear
Default Piston orientation?
Installing front piston and with the arrow facing forward the larger valve relief lines up with the smaller exhaust Valve. 87 electraglide
Old Apr 8, 2025 | 02:53 PM
Dano523's Avatar
Dano523
If stock pistons, then arrow on both pistons will be pointing to front of bike.
If aftermarket pistons, then need photo on the top and bottom side of the piston, and need you to add in direction of arrow on top of piston to the bottom of photo as well.
And to add, really easy to tell which way the piston goes in, since you have the valve relief cuts on the top, but more so the lugs on the piston that tell you which side will be sprocket side to start with.
https://www.hdforums.com/forum/evo/1...ntation-2.html
Old Apr 8, 2025 | 03:12 PM
RANGER73's Avatar
RANGER73
If it's after market they might use different markings.
The arrow might point towards the intake port for that brand.
Consult with the manufacturer.
jdhorvat
Twin Cam Motors
Apr 6, 2023 05:42 PM
terrapin88
EVO
May 9, 2013 10:33 PM
V-RoyD
Exhaust System Topics
Mar 1, 2012 05:22 PM
obwhan
Apr 23, 2011 11:18 AM
2005UltraNC
Jun 10, 2007 02:12 AM
