Some advice please.
Old Apr 19, 2025 | 11:02 AM
chrisflhtc's Avatar
chrisflhtc
Default Some advice please.
I got curious and started looking through my records. I have a memo book that I have recorded damn near everything i have done to my ride since I bought it.
I even recorded the dept store in Ohio where I changed the 600 mile oil on my way to Wisconsin in July of 89.
Anyways I found record of repairing a f'ed key-way and cracked clutch hub on my transmission main shaft and had replaced with a splined shaft and the a fore mentioned clutch.
I cant find the receipts for what I did yet and do not recall what went in the clutch,whether stock or aftermarket.
Would it be possible using an endoscope or just opening the primary, to see the spring plate in the hub without taking it all apart?
What would I look for?
A larger gap between the friction plates?
I have always been a record keeper (Thanks DAD)
TIA
Chris
Old Apr 19, 2025 | 11:14 AM
Rains2much's Avatar
Rains2much
Just remove the clutch primary case cover… should be three screws. I guarantee it’s at minimum an upgraded aftermarket clutch. You can’t hold a 111” motor with a stock clutch. It’s likely a Primo Revera pro clutch, or a Scorpion…
Old Apr 19, 2025 | 11:28 AM
1997bagger's Avatar
1997bagger
If you don't have the compressing tool to release the outer pressure spring, it's stock. Don't believe there is enough room to see through the inspection cover plus the outer clutch housing is enclosed with only small openings for fluid.
Triple-A
Shovelhead
May 18, 2024 09:44 PM
epswing
May 10, 2022 02:59 AM
neeilly23
Feb 13, 2020 10:32 AM
Electric Greaseball
EVO
Jul 7, 2016 09:06 PM
bikered
Dec 30, 2005 09:10 PM
