New Super E = New Cables?
Old Jun 3, 2025 | 01:47 PM
mentalite's Avatar
mentalite
Default New Super E = New Cables?
I made the switch to an S&S and like the easy adjustability vs. the old Keihin butterfly. But I have an issue.....the throttle plate will not fully close. It's not drastic, just enough to keep the idle speed around 1300. It seems to only be an issue once the cables are installed.
The idle cable is slack even when adjusted as tight as possible. I seem to recall reading on here that different (SHORTER?) cables may be required (I did choose the correct cable plate per the S&S instructions). Does the idle cable pull enough tension when correctly adjusted to seat the throttle? If so, will a cable with shorter cable movement fix the issue?
Thanks as always.
Old Jun 3, 2025 | 02:15 PM
Racepres's Avatar
Racepres
If the plate don't shut...you need Longer Inner cable to Outer...Not Shorter.. On Mine, The CV cable is too Long (inner) but the stocker for a Ka-Sneeze works..
Old Jun 3, 2025 | 02:22 PM
Max Headflow's Avatar
Max Headflow
With the non CV carb cables you need the shorter cable holder.
https://www.ebay.com/itm/394534064177?
Old Jun 4, 2025 | 06:24 AM
mentalite's Avatar
mentalite
Thanks, guys.
I did use the shorter cable holder so that's good.
Old Jun 4, 2025 | 02:12 PM
misfitJason's Avatar
misfitJason
Or the way you ran the cables puts them in a bind.
800screws
EVO
Nov 29, 2015 10:58 AM
apetterez
Jan 21, 2015 06:50 AM
Bagged64
Oct 9, 2014 09:39 AM
sidewayzls1
May 26, 2014 05:37 PM
labfreak
Jan 7, 2008 11:51 PM
