Oil Pressure
Old Jun 26, 2025 | 03:19 PM
mdkelley's Avatar
mdkelley
gauge pegs, light stays off
Old Jun 26, 2025 | 03:34 PM
mdkelley's Avatar
mdkelley
I am going to run into town and get a test gauge from harbor freight... maybe just a bad sender. Damn bike is leaking oil now, will have to investigate that.
Old Jun 26, 2025 | 03:52 PM
mdkelley's Avatar
mdkelley
anyone happen to know the low pressure cutoff for this bike? Or, which would make sense?
summit has vdo brand:
Pressure Sender 0-150 Psi 1/8"-27 Thread 11.4 Psi Warning
Pressure Sender 0-150 Psi 1/8"-27 Thread 7.0 Psi Warning
Old Jun 26, 2025 | 06:33 PM
mdkelley's Avatar
mdkelley
2hr trip to town, $30 for a oil pressure test kit...
25psi at idle, sending unit it is. I think the pool of oil on the floor may have actually came out of the sender port while I had it out, there was a wet stream coming from that hole.
Old Jun 26, 2025 | 06:38 PM
t150vej's Avatar
t150vej
OE# 74406-87 $85.
Old Jun 26, 2025 | 06:55 PM
mdkelley's Avatar
mdkelley
that isn't too bad... found this one $22 from vdo, same price at summit racing:
230-504 - VDO Pressure Switch 4PSI - 230-504 - VDO - Gauges VDO from Vehicle Controls
I will call the dealer though, $85 isn't terrible for OEM parts.
Old Jun 26, 2025 | 06:59 PM
t150vej's Avatar
t150vej
That one grounds thru a wire and is for the light only.
Old Jun 27, 2025 | 05:34 PM
mdkelley's Avatar
mdkelley
$87 oem sensor not the solution, behavior is same. Still oil pressure guage pegged out until i ground that wire then drops to 0. Light flickers comes on with part throttle then off with little more. Ground oil light wire get bright red light, that all seems good. Test guage holds low 20s at idle goes up into low 30s with throttle up to 4k rpm. Back to wiring? Really strange behavior but pressure is still good per HF test guage.
Old Jun 27, 2025 | 05:57 PM
mdkelley's Avatar
mdkelley
Yup, wires. Behind pipes. Explains why happened after it got hot, plastic melted and yellow wire for light grounded on pipe. Guess i have a spare sender unit at least now. Gauge must be bad since green wire not affected.
Old Jun 27, 2025 | 10:31 PM
Racepres's Avatar
Racepres
Like said... the pressure sender is ground to Light... melted to ground...= oil light. But, Kind of a First for me!!!
