end play
Old Sep 8, 2007 | 01:12 PM
GAdog's Avatar
GAdog
1st Gear
Default end play
87 FXRS on checking end play with dial indicator gauge, what am I trying to do? do I set contact point in center of axel and rotate tire or should I try and move tire side to side or what? I must be slow but I can learn, I just need to know what i'm checking, service manual is not clear to me
thanks GAdog
Old Sep 8, 2007 | 02:49 PM
SLC Rider's Avatar
SLC Rider
Default RE: end play
This is the best article I found on it, I just did mine a month ago, it's a bit time consuming but easy to do.
http://www.hdrcgb.org.uk/technical/1...l_bearings.htm
What I did was pull the wheel off and clean the bearings with gasoline and brake cleaner. Then I put the wheel back on the bike with no grease in the bearings. I used the magnetic base on the brake disk and put the dial indicator on the center of the axle. Then I "wiggled" the tire back and forth watching the dial indicater. I had .003 on it and the specs for my bike were .002-.006 so I was in range. Then I pulled the wheel back off and packed the bearings with new grease and put it all back together.
Old Sep 8, 2007 | 04:04 PM
GAdog's Avatar
GAdog
1st Gear
thanks for the help brother, Iwill check out the link after football once more thanks for the reply
Strtspdlx
May 31, 2019 08:45 PM
LQQK_OUT
Wheels/Tires
Oct 11, 2018 12:23 PM
chevdude
Aug 2, 2011 11:12 PM
tugman
Jul 5, 2011 06:42 PM
TalkLikeAPirate
Oct 11, 2006 09:33 PM
