rear brake
Old Dec 20, 2025 | 12:49 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Originally Posted by marcelm
I have connected the two wires coming from the hydraulic banjo bolt, to the multimeter, then pressed the pedal. Nothing happened. Means the switch from the bolt doesn't close.
But when I remove the hydraulic banjo bolt, connect it, again, to the multimeter and push inside it with an thin allen key, the switch closed (as in the picture).
Maybe not enough pressure in the system, or some air bubbles inside the hydraulic switch, I notice the hole inside of it is quite deep.. air can be trapped there... just thinking
Air compresses, unlike brake fluid, air may be the issue.
Somehow, I have yet to hear you say pressing with the allen made the rear light work.
Last one I installed, screw type, I quickly screwed it in a few turns leaving it loose. I lightly applied brake pressure letting fluid drip out.
Try elvating it bike. I once broke a bleeder off. I just pulled the caliper and with it angled correctly, and a block between pads, blead it with the banjo fitting.
Lot of people have trouble bleeding front brake from putting bars In wrong position.
Old Dec 20, 2025 | 01:09 PM
marcelm's Avatar
marcelm
When I push with the allen, the switch close, I have checked with the multimeter, means the rear light will work. So, I assume the hydraulic banjo bolt switch is ok.
I also loosened the damn screw and let the fluid drip out, but did not help.
I will try tomorrow to elevate the front of the bike, to make it easier for the air to escape.
By one side, I think there is air inside the bolt, which makes the switch not to work. But, then, I do not understand why the pedal is so firm when pressed.
Old Dec 20, 2025 | 01:13 PM
Joe12RK's Avatar
Joe12RK
When I push with the allen, the switch close, I have checked with the multimeter, means the rear light will work..
I'm not trying to be rude, but you've proven the switch works, but not that the bike wiring is good. It's a simple thing to touch the bike wires together with the key on and check it out.
Old Dec 20, 2025 | 01:23 PM
marcelm's Avatar
marcelm
No problem..
I did that, in the beginning, the light & wiring is working well.
Old Dec 20, 2025 | 01:43 PM
Jackie Paper
Usually with a little air, you can pump up a firm pedal but the next day , pedal will drop a little till you pump it.
Always after any brake work and bleeding, hold a firm pressure as hard as you brake for one minute. Pedal or lever should not drop.
Old Dec 25, 2025 | 08:10 AM
98hotrodfatboy's Avatar
98hotrodfatboy
You obviously have an air bubble in the switch. I've never used that style switch but have had an air bubble at the stock switch on my softail and if you step really hard on the brake pedal "REAL HARD" it will come on.. Seeing that the switch is beyond the brake line it's very possible the air is not coming out.. Creating a better angle to the bike allowing the banjo bolt to be the lowest part in the system (compared to the master cylinder and brake line) might help.. I would pump the pedal lightly when the bike is at angle to help assist in removing the air.. Maybe even tap gently on the banjo bolt and do it with the cap off the reservoir..
Merry Christmas....
Old Dec 26, 2025 | 03:31 AM
marcelm's Avatar
marcelm
Merry Christmas....
Merry Christmas to all of you!
This is exactly what I suspect, a small air bubble into the hydraulic banjo bolt switch.
Small enough to allow the brake system to perform well, but big enough that the switch doesn't work.
I lifted the front of the bike, maybe 45 degrees, so that the air can escape easier from the inside of the bolt, primed the installation, but no results. Pressed hard on the brake, almost to bend the pedal bracket, no results.
I ordered a new banjo bolt switch, from a different company, maybe it has a different internal architecture and can be primed easier. But, if no succes, I will install a mechanical switch, and replace the hydraulic bolt. I cannot go back to stock because this is a custom project.
Thanks
Marcel
Old Dec 26, 2025 | 06:47 AM
Joe12RK's Avatar
Joe12RK
Have you tried removing the whole caliper with the hose attached and moving it so the switch can release its bubble? Let it set overnight
Old Dec 26, 2025 | 08:19 AM
Max Headflow's Avatar
Max Headflow
If you can generate enough pressure to activate the brakes you will generate enough pressure to activate the switch. Pressure inside a closed system be liquid or air is the same throughout the system. The switch is defective. Simply pushing a rod into the switch simply mean that contacts are good. The disc that is inside the switch lost it's seal.
Old Dec 27, 2025 | 12:06 PM
98hotrodfatboy
Normally yes.. but air will compress at a different rate than fluid.. That's why I said earlier if you stand real hard on the brake the switch might activate..I had this same issue with the stock switch and block..
