Play in handlebars
Old Dec 21, 2025 | 09:06 AM
FWR's Avatar
FWR
Default Play in handlebars
1992 FLHTP, Batwing fairing.
Feels like there is a tiny bit of back-and-forth play in my handlebars. They are not "loose" or slipping. They feel like they just slightly rock back and forth. I can get to the bottom of what looks like the post of the handlebar clamps and they are tight. Before I dig into anything, anybody have any ideas about what needs to be tightened and how to get to it?
Old Dec 21, 2025 | 09:16 AM
RDHIGH's Avatar
RDHIGH
Your hbars risers are 'rubber mounted' for lack of a better term- you can see the rubber bushing in your photo.
A bit of movement is normal.
You can swap out the rubbers with urethane bushings to tighten them up- or even eliminate the bushings with a kit to solid mount them- but either will probably cause more vibration transfered to your hands through the bars.
I tried early on to solid mount my bars- and changed them back quickly when my hands kept going numb.
Old Dec 21, 2025 | 09:27 AM
FWR's Avatar
FWR
Thank you! I knew I felt something but it did not feel like they were "dangerous" (?).
I guess in a shaky old war-wagon like this a little bit of play can be a good thing!
Old Dec 21, 2025 | 09:32 AM
rizzo's Avatar
rizzo
Replacing the rubber bushings will make a world of difference - at least it did on my '94.
Old Dec 21, 2025 | 10:44 AM
FWR's Avatar
FWR
And how hard is that job?
Old Dec 21, 2025 | 11:14 AM
SparkyD's Avatar
SparkyD
On a scale of 1-10 I give it a 2
Old Dec 21, 2025 | 01:38 PM
IBDAGRIZ's Avatar
IBDAGRIZ
Default I'm more like a 6
Just because of dealing with the batwing fairing. Radio isn't too bad but it's still going to take a minute.
Griz
Old Dec 21, 2025 | 04:12 PM
FWR's Avatar
FWR
So the front of the fairing and the stereo have to be removed?
Old Dec 21, 2025 | 06:43 PM
IBDAGRIZ's Avatar
IBDAGRIZ
I'm not sure exactly how it looks but you need access to the riser bolts and nuts on the bottom and be able to pull the bars out of the way to pull the riser to get to the bushings. You have a good picture of the bottom. Now what does it look like from the top?
Griz
Old Dec 22, 2025 | 06:29 AM
Bubba Zanetti's Avatar
Bubba Zanetti
If it’s a small amount of back and forth movement I’d just leave it alone.
They’re supposed to move to help reduce vibration. If you replace the bushings with urethane you’ll have a lot more hand vibrations.
