Evo Leakdown Test Results
Old Dec 19, 2008 | 02:13 PM
miacycles's Avatar
miacycles
Exclamation
Originally Posted by jpooch00
OK, I'll ask a question that shows my ignorance! Is a leakdown test the same as a differential pressure test that's done on airplane piston engines where you feed a specified amount of pressure into the cylinder and note the pressure difference on either side of a calibrated orifice? I did this type of test on my '94 FXDL and got 78/80 on the front and 79/80 on the rear. On an airplane engine that's considered excellent. I did a regular compression test too and got 125 PSI on both. My engine is bone-stock. Any advice/info much appreciated!
Yes except thye guage is a little different. You set it to the set point (zero) on the guage. Then you open the valve and the needle will move up the guage indicating what percentage of leakage you have. On an everyday V-8 engine 20% is ok. However a V-Twin having only two cylinders 10% and more can affect performance and mileage. That being said always treat the patient not the gauges. If you are happy with the way the bike runs, then by all means ride it. Hope this helps.
Old Dec 20, 2008 | 09:34 PM
blackjack66's Avatar
blackjack66
2nd Gear
+1 by all means ride it, just be aware that there is a problem, and you will be going in soon to rebuild, assuming you have a true and correct 305 leakage. I would unadjust the pushrods and reset the piston just below TDC compression and check again. 30 is alot! Your compression is OK for a stone stock bike, but with some headwork, I look for higher, like 180 or so, my bikes have 10.5-1, and with edelbrock .600" cams they show like 200 psi. they make 85 - 90 HP from 80 in., though
pest889
General Topics/Tech Tips
Aug 30, 2014 07:55 AM
pest889
Engine Mechanical Topics
Huskerjim
Exhaust System Topics
23
Jan 18, 2014 03:55 PM
mysiar
EVO
Sep 29, 2012 02:20 PM
ridefree1
Ironhead
Mar 18, 2011 07:34 PM
