Leaky Rocker Box
Old Apr 28, 2012 | 10:32 PM
Jethro's Avatar
Jethro
Originally Posted by Greg Rosa
i need too know what the sequence is too tighten rocker box on a 96 flhtc evo and the torque please help
I have done this, and had bad results both times. An "indy"mechanic who is probably one of the best mechanics I've known told me the following... "New seals totally clean with no lubricant. Flat boxes. You use a cross pattern to tighten, start wherever you want. Use an allen wrench that you have cut off to shorten the head on the bolts you can't reach. Forget torque settings. You tighten these bolts until they feel like metal to metal contract. When you look at the boxes they should appear to be touching.. basically again appearing metal to metal. Did it this way and no leaks, no shifting of boxes.
aRedGoneBlue
Aug 12, 2014 12:54 PM
chop66
EVO
15
May 19, 2014 07:43 PM
Tomahawk246
Exhaust System Topics
Mar 28, 2009 09:08 PM
hotrod351
Mar 6, 2006 10:44 AM
harley
Aug 30, 2005 10:00 AM
